How do you create a corner window with only a post at the corner? I know there is a corner glass window posted on RUGI. But I need it w/ a post. Thanks
Could you place two windows and a structural post and satisfy your needs?
If not you should be able to create a family using a single window you like and add a second at the angle you are looking for.
Of course I could be completely misunderstanding what you want?
I think that if you make your window with a void instead of an opening cut it will let you slide it right to the edge of the wall and beyond, then you only need a standard window, not a corner window, and the post canb be inplace or a column or whatever you choose.
P
I accomplished this with windows 90 deg apart with the frames at the center in a common location - the corner. (It was about a month ago, but I'm pretty sure that's what I did).
Good luck.
You can also refer to: The FAQ on how to create a corner window in Revit.
Location: go to the Autodesk Revit home page. Select Support / Support FAQ / Design Bar / Basics / Window / How can a corner window be created?
I have also attached a corner window w/ pole that I created a couple of years ago. It should still work.
I hope this helps.
Joe,Originally Posted by jkendsersky
I don't think the link is working ?
beegee
Hmm... I'll have to see why this is not active. I have created a .PDF file with the instructions for now.
Please do, It's been down for a few days now. Thanks!Originally Posted by jkendsersky
Chris
SOM | New York
