Results 1 to 10 of 14
Thread: metric to imperial conversion (vice versa)
    Member Chris Matira's Avatar
    2005-08
    Philippines
    41
    Default metric to imperial conversion (vice versa)
    if you ever need to convert a metric drawing into imperial (ie. meters to feet)... instead of using the traditional scale command, a neat trick is to insert the drawing to be converted as a block into an imperial template. all units will then be converted... when you explode the inserted block, even the dimensions will follow.
    just make sure the your source drawing is in the proper units before inserting it to the template you want it to be converted into...
    this works best in working with large drawings since it will take lesser time for your computer to process the command and dimensions are also adjusted...
    2004-07
    Detroit Michigan
    2,508
    Default Re: metric to imperial conversion (vice versa)
    That is a good tip. I have lisp routines defined to scale between english and metric.
    Your tip seems easier. I like the added benefit of getting the dimensions to change.
    2005-12
    2
    this is fascinating,i like it .i've been having this problem ,am changing imperial hardcopies into autocad 2005 ,i've never done imperial units never , is there a faster way of doing this, it's one my targets at the office,need help!!
    Hannock Kafakamoyo
    Drawing Office Supt.
    Blantyre Water Board ,Malawi.
    2005-08
    Philippines
    41
    Quote Originally Posted by hkafakamoyo
    Hannock Kafakamoyo
    did i get it right, you are converting imperial hardcopies... so this means your converting your hardcopies into softcopies in acad2005 version...
    well, the best way to do this quickly is to use Raster Design... it's an acad add-on... you need first to have your hardcopies scanned, then insert it as a raster image on acad...
    Raster Design has features which could help you in your problem... quickly and easily!
    2005-12
    2
    Smile Re: metric to imperial conversion (vice versa)
    Quote Originally Posted by Chris Matira
    hi,
    you got it right Chris, thanx very much,i have to go for raster design training.
    2005-02
    39
    ok, I know this is old, but I could use some help figuring out how to convert my metric drawings to imperial given the aforementioned strategy. I have an imperial template ready to go, and a metric drawing which I have inserted into this drawings as a block. I made sure the INSUNITS was set to 1 which is inches, but I can't seem to locate something that might tell autocad that the drawing being inserted is in millimetres. The insert drawing prompt window has an area called Block Unit and there is says that drawing is "unitless" - i think this is where the problem is - how do I change this?
    I need my dimensions to change to imperial, along with the drawn lines themselves.
    thanks for the help in advance..
    2005-06
    in the upper right corner
    3,296
    Quote Originally Posted by gabriel_friedman View Post
    Here's some info that may be of some help, check these variables on each drawing:
    INSUNITS - Specifies a drawing-units value for automatic scaling of blocks, images, or xrefs inserted or attached to a drawing.
    INSUNITSDEFSOURCE - Sets source content units value when INSUNITS is set to 0. Valid range is 0 to 20.
    INSUNITSDEFTARGET - Sets target drawing units value when INSUNITS is set to 0. Valid range is 0 to 20.
    Also look at This Thread for further information.
    I hope this helps
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    0,0,0 The Origin
    8,570
    For the geometry, just scale the block up by 25.4 then Explode it.
    For the dimensions, change them to your normal imperial Dimstyle.
    John B
    2005-02
    39
    jaberwok, are you saying that the earlier post, the one that suggested that the dims already drawn would be automatically scaled, is not right? i was hoping that the metric dimension lines would just auto-correct themselves.
    all those references I had discovered before - still I am not understanding what to do...I have the insunits down, just not understanding how to get autocad to understand that the file being inserted is drawn in millimeters.
    0,0,0 The Origin
    8,570
    I'm going to back up a bit.
    The original suggestion does work but you need to open your metric file and set INSUNITS to 4 (for mm) and save it. Then insert it in your imperial drawing with the Explode box in the Insert dialogue checked. (I don't see this bit mentioned in Help.)
    John B
  1. 2013: Making an Imperial Template from a Metric Template or vise-versa
    By Jonny in forum Revit - Platform
    Last Post: 2013-06-06, 07:45 PM
  2. Metric to Imperial conversion
    By jonathanschade in forum Revit Architecture - General
    Last Post: 2009-12-13, 09:10 PM
  3. ACAD from ArcView? vice versa?
    By CAD_trpd in forum Software
    Last Post: 2008-04-18, 08:07 PM
  4. Sketchup to Revit... or vice versa?
    By jisbiste in forum Revit - Rendering
    Last Post: 2007-02-21, 08:57 PM
  5. Revit to Vectorworks and vice versa
    By WolffG in forum Revit Architecture - General
    Last Post: 2006-12-16, 01:31 AM
