Thread: Database help
    2006-01
    Default Database help
    Hi Everyone
    Really was not sure where to post this, so if it is more appropriate on another forum please feel free to move.
    So the scenario is
    I have a sql database populated with amongst other things attributes written out from dwg building floorplans with links to web based dwfs to enable end users to view the drawings in dwf format over the t'internet.
    I have been asked how we can create a live link from dwg to sql.
    The requirements being that if somebody adjusts a closed polyline in the cad file the area is recalculated in the database field.
    I have looked at dbconnect and appreciate l can update labels/attributes from the dwg causing the database fields to reflect thest changes.
    Assuming this is achievable how could I (easily) populate the database with the closed polyline info from my existing dwg's?
    Indeed is there an easy way to reference all the existing database fields to the dwg attributes, as at present the two are unrelated(not linked)
    Turlock, CA
    5,756
    Default Re: Database help
    Have you tried DbConnect?
    C:> ED WORKING....
  1. Cannot open Database...
    By .chad in forum ACA General
    Last Post: 2008-07-16, 06:56 PM
  2. Point database
    By cadtag in forum AutoCAD Civil 3D - General
    Last Post: 2007-08-27, 01:05 AM
  3. connection to sql database
    By sdickson in forum AutoCAD Customization
    Last Post: 2005-08-04, 11:30 AM
  4. Keynote Database
    By Chuckyd67 in forum ACA General
    Last Post: 2005-05-23, 11:45 AM
