Thread: Attaching image files in AutoCAD with out drawing paths
    2001-08
    13
    Default Attaching image files in AutoCAD with out drawing paths
    I need to attach an image file into AutoCAD without and drawing path so I can e mail the file and the image in the same file. Any info would help. Thanks!!
    13,656
    Default Re: Attaching image files in AutoCAD with out drawing paths
    Hi
    Have you looked at using the AutoCAD command ETransmit ?
    If you sure about wanting to embed an Image inside an AutoCAD drawing file, take a look at the following posts...
    Problems inserting a logo in a drawing
    RE: Removing a link
    RE: Save dwg with attached image name
    Hint - you may want to spend the time and read the actual threads that the above posts belong to.
    Disclaimer: Embedding Image file inside AutoCAD drawing files can lead to huge! drawing file size, plus in some cases can lead to drawing file corruption.
    Have a good one, Mike
    Earth
    9,803
    Quote Originally Posted by akall
    Do you mean you want to embed the image into the DWG file? If so, see: http://rkmcswain.blogspot.com/2005/0...er-images.html (Updated URL = http://cadpanacea.com/wp/?p=1402)
    If you just want your recipient to be able to see the image without embedding the image or using eTransmit, just zip up both files (without using paths in the zip file), and then tell your recipient to extract both files to the same directory. As long as the image is in the same directory are the DWG, it will be "found" regardless of the saved path.
    Last edited by rkmcswain; 2017-10-06 at 01:56 PM. Reason: fix formatting and update URL
    R.K. McSwain | CAD Panacea |
  1. Replies: 2
    Last Post: 2007-06-12, 11:23 AM
  2. Replies: 4
    Last Post: 2007-05-23, 04:37 PM
  3. Plot drawing file (containing image files) to PDF
    By janetteallan713244 in forum AutoCAD Plotting
    Last Post: 2007-02-01, 05:37 PM
  4. Replies: 4
    Last Post: 2006-10-09, 03:10 PM
  5. AutoCAD 2005 TIFF Image files - Image file not valid
    By richard_hamilton in forum AutoCAD General
    Last Post: 2004-09-30, 11:39 PM
