Results 1 to 10 of 12
Thread: line extends THROUGH line to another line in the drawing
    2004-05
    Chambersburg, PA
    53
    Default line extends THROUGH line to another line in the drawing
    I have a situation in which I tried to trim a line back to a line that I thought was attached perpendicularly to my line that I was trying to trim. It would not and when I zoomed in I can see that the line I was trying to trim back to was actually a very short distance away from the line I was trying to trim. When I try to extend the perpendicualr line to the line I am trying to trim, it goes THROUGH the line and extends to another line on the drawing.
    Is there a system variable that needs to be modified?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,124
    Default Re: line extends THROUGH line to another line in the drawing
    Quote Originally Posted by mhudson
    Are the two lines at the same elevation?
    2004-05
    Chambersburg, PA
    53
    yes - that was one of the first things I checked.
    I believe there is system variable that is similar to a 'gap tolerance' - not the one associated to hatching, but one that is associated to this particular situation.
    Thanks for you reply.
    2002-01
    jUSt Here (a lot)
    9,124
    Which version are you using?
    2004-05
    Chambersburg, PA
    53
    AutoCAD 2006
    2002-01
    jUSt Here (a lot)
    9,124
    AutoCAD 2006
    Have you tried the Project and/or Edge methods of the trim command?
    2004-05
    Chambersburg, PA
    53
    I used the Edge method to get around the problem. I don't mind the workaround, but I've had others in the office complain of the same ocuurence and I have been trying to find the origination of the problem.
    2002-01
    jUSt Here (a lot)
    9,124
    Forgive me but I am just trying to verify. You did say the two entities were at the same elevation. Do either one have a differing elevation on one end?
    2004-05
    Chambersburg, PA
    53
    Z value is 0" at all points.
    2002-01
    jUSt Here (a lot)
    9,124
    Okay, I was just checking. I'm still stumped as to why it happens. I have had it happen to me before, but it was due to having differing z coordinates.
    I am glad you found a work-around anyway. Maybe someone else can point you to the proper solution.
  1. 2010: making all line segmentsof same line type show as one line segment
    By Darren Allen in forum AutoCAD LT - General
    Last Post: 2015-09-02, 10:35 PM
  2. Replies: 0
    Last Post: 2013-11-15, 03:50 PM
  3. Replies: 2
    Last Post: 2012-07-13, 09:04 PM
  4. Replies: 8
    Last Post: 2007-06-27, 09:09 PM
  5. Replies: 1
    Last Post: 2006-06-01, 04:49 PM
