Thread: Already zoomed out as far as possible
    2013-06
    Default Already zoomed out as far as possible
    When using scroll on mouse in/out the dwg reports "All ready zoomed out as far as possible". Zoom real-time still works but slows functionality. Attempts to Regen, zoomed extents, zoom scale...etc tips have not remedied the problem. Who knows the corrective action for this problem? Running drawing recover finds no errors. Tried wireless and usb mouse. Zoom real-time still works but slows functionality.
    2012-05
    93
    Default Re: Already zoomed out as far as possible
    Try the undocumented suboption _V of the ZOOM command.
    By the way, does it happen only on a particular drawing, or always?
    Tallahassee, FL USA
    3,667
    Same here, each time I regen I can scroll out a little more. Probably related to the system variables EXTMAX & EXTMIN. They store the upper-right & lower-left points of the drawing extents. Expands outward as new objects are drawn; shrinks only with ZOOM All or ZOOM Extents. May also be a limit of our video cards.
    There should never be any objects outside of that so it shouldn't be a issue very often.
    2008-03
    Maryland
    54
    it's that or you have annotative stuff it needs to regen. Sadly I actually had to turn off my "hardware acceleration" option just to have a better and more stable performance. Talk about a waste of money. Even the Autodesk site said my video card was certified for C3D.
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    Have you tried using RegenAll? Another thing you can check is in Options - Cache - change this to Cache last active layout to speed things up.
  1. Can't See Inserted Image When Zoomed
    By salarch2 in forum Revit Architecture - General
    Last Post: 2010-06-28, 10:31 PM
  2. Zoomed in to far on Viewport
    By KWDWallace in forum AutoCAD General
    Last Post: 2010-06-02, 11:02 PM
  3. Skewed Perspective when zoomed.
    By caad9 in forum AutoCAD General
    Last Post: 2008-12-24, 10:44 AM
  4. Dwg that reduces to a point when zoomed extents.
    By innabro in forum AutoCAD General
    Last Post: 2005-10-21, 03:09 AM
  5. zoomed view reverting to previous
    By gbrowne in forum Revit Architecture - Wish List
    Last Post: 2004-11-24, 11:11 AM
