Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Area in metric from English units drawing
    2004-07
    Detroit Michigan
    2,508
    Default Area in metric from English units drawing
    I need a lisp routine that:
    Selects an object (polyline, hatch, etc.)
    that is drawn in english untis
    and
    Returns the area in metric units mm^2
    Anybody know how to do this?
    2015-12
    Central Oregon
    591
    Default Re: Area in metric from English units drawing
    You can supply the selection & area portions, this will convert the area to mm^2:
    (cvunit 60.0 "feet^2" "mm^2")
    (cvunit 60.0 "inch^2" "mm^2")
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Here is a quick and dirty that should work for hatch or polyline entities for getting the raw area, but I didn't try it on lines, arcs, etc.:
    (defun c:getarea (/ e vlaobj)
       (setq e (entget (car (entsel))))
       (setq vlaobj (vlax-ename->vla-object (dxf -1 e)))
       (vlax-get-property vlaobj 'Area)
    );defun
    It should at least get you started.
    Take care,
    Tim
    2004-07
    Detroit Michigan
    2,508
    Ok, that is giving me:
    Select object: ; error: no function definition: DXF
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,197
    Quote Originally Posted by Robert.Hall
    Robert,
    Try this function. It appears Tim has a routine to extract some data from an entity's group code data.
    (defun DXF (ELEMENT ENTITY /) (cdr (assoc ELEMENT ENTITY))) ;;; retrieve assoc data from entity
    Tim, If the above code is not right, please let Robert know. Just trying to help out.
    2004-07
    Detroit Michigan
    2,508
    that solves the dxf error
    however............
    ; error: ActiveX Server returned the error: unknown name: AREA
    2002-01
    jUSt Here (a lot)
    9,197
    however............
    I can't fix everything.
    I'll see what I can come up with after lunch, if I have time.
    2002-01
    jUSt Here (a lot)
    9,197
    Just a quick thought. Have you tried adding (vl-load-com) to the beginning of the routine?
    Lost
    1,473
    Oops, sorry,
    In my haste, I forgot to give you the dxf function:
    (defun dxf (code elist)
    (cdr (assoc code elist))
    );defun
    Also, it looks like it only returns the area for those items that have area (i.e. hatch and polylines).
    I hope this helps.
    By the way, from personal experience, it is possible to golf in the snow. It's pretty frustrating when the ball turns into a snowball and won't fit in the hole, though.
    Tim
    2004-07
    Detroit Michigan
    2,508
    So I have an area returned, however, it isn't converted.
    I have been messing around with converting the output
    and I have not had any success. Where in this code do
    I add the conversion?
    (defun c:aw (/ e vlaobj)
    );defun
    );defun
  1. Grid in English units, CL elevation in Metric?
    By SRBalliet in forum AutoCAD Civil 3D - Sections
    Last Post: 2008-06-17, 03:18 PM
  2. Change the units of dimensions from Metric to English
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2007-02-21, 01:36 PM
  3. Scale drawing from metric to english
    By andycrox in forum AutoCAD General
    Last Post: 2007-01-23, 03:35 AM
  4. AEC dims showing metric in an english drawing
    By jonesb33145 in forum ACA General
    Last Post: 2005-03-28, 06:49 PM
