Results 1 to 6 of 6
Thread: 3d lineweights
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Default
    Our office has recently started doing some small Hidden Line vignette's on our cd's since revit has the capability to do this quickly and easily and it (hopefully) give the contractor a better grasp on the final project. However, it seems that everything on these 3d drawings comes out as lineweight 1. Is there a way to change that?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: 3d lineweights
    Well I thought the projection lineweight controlled it, but just did a test and you can change the color but not the lineweight so you are correct you can't do it without adjusting your number 1 pen weight to be heavier, but this would effect all your views.
    Scott D. Brown, AIA
    BECK
    2003-11
    New Zealand
    1,116
    Are you using phases? If so it might have something to do with your phase filters.
    Guy
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    If you take your 3D view, place it on a sheet, & then export it to .dwg or .dgn, You'll get a 2d (flattened) representation with all the lines, hatches, etc, assigned to layers per Revits export template.
    You can then either re-import the .dwg to a drafting view, and then go to object properties to assign lineweights & colors to layers.
    Or you can open it in any competing cad package that can read the file...
    2004-01
    1,535
    yeah, I could do that, and I may have to. I could also do the same with an image file, but that would require updating the image or cad file when the design changes. I was hoping to avoid that...
    2003-05
    Coast to Coast
    4,440
    I think this would make a good wishlist item, perspective view lineweight added to the projection/cut choices. Projection should be the default.
    Scott D. Brown, AIA
    BECK
  1. NCS -Lineweights
    By Lifes_Blissful in forum CAD Standards
    Last Post: 2010-10-15, 05:14 PM
  2. Lineweights
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2009-08-15, 05:12 AM
  3. Lineweights
    By ROBinHI in forum Revit Architecture - General
    Last Post: 2009-04-09, 02:52 PM
  4. DWG to PDF & Lineweights
    By wbs69117950 in forum AutoCAD Plotting
    Last Post: 2007-05-30, 10:00 PM
  5. Lineweights - CTB's or STB's
    By kschultz in forum AutoCAD General
    Last Post: 2006-05-16, 01:52 PM
