Is it possible to transfer customized toolbars frm AutoCAD 2005 to AutoCAD 2006?
Hi
Please note I have *moved* this thread from the AutoCAD General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Maybe trying plugging in the following search criteria in the forum search facility ( hint - limit search to AutoCAD 2006 CUI Menus forum, AutoCAD 2006 General forum & AutoCAD Customization forum )...
Key Word(s): *Transfer* + *Toolbar*
*Import* + *Toolbar*
Have a good one, Mike
No problem at all. Just take the menu in which these toolbars are defined (kparr.mnu), and load it as a partial menu in 2006 using MENULOAD. Your toolbars are defined in a partial menu in 2005, right? If not, now is the time to start.Originally Posted by kparr
There is actually no need to mess with the CUI, unless you are getting into a more detailed configuration, such as configuring which pull-down menus are shown and in which order. For toolbars, you can turn them on/off, change their position, and save a workspace without getting into the CUI.
R.K. McSwain | CAD Panacea |
