Results 1 to 10 of 13
Thread: Very Slow Printing / Plotting
    2006-01
    22
    Question Very Slow Printing / Plotting
    Hello all,
    I have a question about plotting / printing. Our office began using Revit 8 weeks ago, and we love it and everything has been going well. This forum has been of great help.
    But, we recently moved in to CD's on one of our projects and created a sheet with 6 building sections on it, and it takes an hour to print the sheet. If we try to get a preview, it hangs and crashes Revit before it brings up the preview
    Does this seem unusually long, or do these views take this long when complicated? If we print one view it also takes a while which makes me think its just the model size...
    We're just printing hidden line views, vector, with short (10') view ranges established when we create the section markers.
    We are an established office with a server, good practices ( I hope), decent computers, etc.
    Thank you,
    David Lancor
    PBC+L Architecture
    Asheville, NC
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Default Re: Very Slow Printing / Plotting
    I don't know how big or complex your wall sections are, but we have not had this problem (althought we don't do really large buildings). Do you have shadows turned on by chance? that will slow printing down significantly.
    Hopefully someone else will have a better answer, but something to check...
    2002-02
    St. Louis, MO
    4,695
    Are these CD's? Do you have Advanced Model Graphics turned on?
    If they are construction type drawings, they should print in a few seconds. I can do a whole job in the time you are talking about.
    If you are trying to print shadows, they can take a long time....
    2006-01
    22
    Aaron and Steve,
    Well, we do not have advanced graphics turned on.
    It is simply a CD sheet, without any notes, with 6 building sections (and our buildng is only one story tall!). It is not a complicated geometry, but does show many roof trusses, and some detail.
    2003-09
    1,907
    Quote Originally Posted by dlancor
    Hello all,
    What kind of memory on the graphics card? Are you running open windows. Also what speed machine and how much ram? Also, are you spooling the plot over a network, or plotting direct to a
    plotter. How much memory is in plotter?
    I have found that Revit generates a much larger plot file than Acad, so there are some differences that must be addressed.
    I could stop if I wanted to neb1998's Avatar
    2004-06
    Chicago
    373
    Aaron and Steve,
    What is taking a long time? Revit actually finishing the software printing process or the printer processing the job? Meaning at the bottom of the screen does it say PRINTING...and then the percentage sits at like 50-60 perrcent for a long time or does it finish and then the printer takes a long time to process the file?
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Also, Revit's method of "ripping" to create the plots is quite intense; evidently some printer drivers won't put up with it. Then you'll have to print to DWF first or PDF, and then print that.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    try adjusting the far clip plane so its only showing what needs to show. try 2 things first change it to just 1", see if the print goes quickly, if so that means there are lots of things in the distance revit is having to "hide". If thats not it,make sure all dwgs are turned off.
    Scott D. Brown, AIA
    BECK
    2006-01
    22
    Ben,
    When we print (or try to generate a preview), it zips up to 50% complete, and then hangs there for a long time before sending to the printer.
    I am farily new to the firm, and now that I look at our computer properties, it appears we are just running with the integrated Intel Graphics controller - I am amazed at how well our computers handle Revit considering that!
    But, we are using Pentium 4, 3.2 ghz, with 1GB of RAM - is this not fast enough?
    I will also try to change the view depths to 1' instead of 10' and see if there is a modeling issue....
    Thank you all,
    David
    2006-01
    22
    More specs...
    We are plotting to a HP Designjet 1055 or printing to a Canon C3220 (copier / printer) - the same problem happens either way, which makes me think that it is our computers or model.....40 minutes is a very long time.
    David
    PBC+L Architecture
    Asheville, NC
  1. AutoCAD/LT Slow when Printing
    By jake.golde397203 in forum AutoCAD LT - General
    Last Post: 2011-09-15, 12:20 PM
  2. Slow printing?
    By patricks in forum Design Review - General
    Last Post: 2009-12-11, 12:31 AM
  3. Replies: 6
    Last Post: 2006-05-23, 09:40 PM
  4. slow printing Shadows got you down? try this!
    By hand471037 in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-12-09, 01:12 PM
  5. Slow printing
    By jfudo1892 in forum Revit Architecture - General
    Last Post: 2004-03-29, 09:17 PM
