Thread: Redefining Dynamic Blocks - Layer Colors not updating
    2005-11
    Daly City, Ca.
    41
    Default Redefining Dynamic Blocks - Layer Colors not updating
    I'm having difficulty redefining the layers of a dyn block that i have inserted in a drawing. I inserted a block in a number of drawings and changed my mind and wanted to change the color of some layers on the block.
    I modified the block, reinserted it and redefined the block. Unfortunately the layer colors didn't update? Am I doing something wrong. I have an updated block w/ new colors but I can't redefine the block in the drawings that I inserted the block in w/out doing it manually for each drawing. There's got to be a simpler and more efficient way of doing this.
    Help. Please
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,137
    Default Re: Redefining Dynamic Blocks - Layer Colors not updating
    Quote Originally Posted by sumulong
    Help. Please
    If the layers are already defined within your drawing, no amount of block insertion (with same layer names) will make those layers change. You would most likely need to purge the drawings of the common layers before the insertion corrects the layers for you.
  1. Updating blocks nested within Dynamic Blocks
    By mattr.143859 in forum Dynamic Blocks - Technical
    Last Post: 2009-09-30, 04:14 PM
  2. Redefining Dynamic blocks
    By ccowgill in forum Dynamic Blocks - Technical
    Last Post: 2008-09-25, 04:54 PM
  3. Redefining old Blocks to new Dynamic Blocks
    By dgriessmann.86073 in forum AutoCAD General
    Last Post: 2006-10-31, 09:41 PM
  4. Redefining your Dynamic Blocks
    By whdjr in forum AutoCAD Tips & Tricks
    Last Post: 2006-06-27, 02:51 PM
  5. Dynamic Blocks Not Redefining
    By Rico in forum Dynamic Blocks - Technical
    Last Post: 2006-02-07, 07:50 PM
