Results 1 to 10 of 12
Thread: vlax routine perpendicular lines along polyline.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,747
    Default vlax routine perpendicular lines along polyline.
    I am working on this routine to draw perpendicular along a polyline. This routine will be creating some 3d geometry based on a couple of 3D pick points. The problem I haven't figured out just yet is how do I calculate the perpendicular angle at a specified distance along the polyline.
    I have attached the code that will place a POINT entity at the selected places. The inserted point will be replaced with some code to draw the necessary 3d geometry. I already have the 3d geometry code written. I just need to calculate the perpendicular angle of the polyline. The polyline will most likely contain some kind of arc and possible more than one arc and a tangent.
    (defun C:TEST ()
      (setq	ENTITY	    (entget (car (entsel "\nSelect alignment: ")))
    	VLAX-ENTITY (vlax-ename->vla-object (cdr (assoc -1 ENTITY)))
    	VLAX-LENGTH (if	(vlax-property-available-p VLAX-ENTITY 'length)
    		      (vlax-get-property VLAX-ENTITY 'length)
      (setq OSM (getvar "osmode"))
      (if VLAX-LENGTH
        (progn
          (setq INCREMENT (fix (/ VLAX-LENGTH 3.0)) ;_ Arbetrary length of 3.0 for testing.
    	    INCREMENT (/ VLAX-LENGTH INCREMENT)
          (setvar "osmode" 0)
          (repeat (- (fix (/ VLAX-LENGTH 3.0)) 1)
    	(setq VLAX-LENGTH (- VLAX-LENGTH INCREMENT))
    	(setq TempPoint (vlax-curve-getpointatdist VLAX-ENTITY VLAX-LENGTH))
    	(command "_.point" TempPoint)
    						  ; This is the place in the code I need to calculate
    						  ; the perpendicular angle of the polyline.  As you can
    						  ; see this angle will change based on where along the
    						  ; polyline the point is located.
      (vlax-release-object VLAX-ENTITY)
      (setvar "osmode" OSM)
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: vlax routine perpendicular lines along polyline.
    vlax-curve-getFirstDeriv will return a direction vector indicating the direction of the polyline at the given point. If the point is in a curve, the direction vector is the tangent at that point. You will need to rotate the bearing ±90° yourself to get the crossing vector.
    Working with polylines can get a little tricky, since the polyline has a certain direction. The vector returned by vlax-curve-getFirstDeriv is based on the polyline direction, which is determined by how the polyline is created.
    (But unlike arcs, at least polylines HAVE a direction... Arcs always go counter-clockwise, which is sometimes a royal pain.)
    2002-01
    jUSt Here (a lot)
    8,747
    Quote Originally Posted by richards.64879
    Thanks for that. I'm still learning the vlax- routines. The help file wasn't very helpful on this topic so I brought it here.
    I know about the arcs. The routine I am modifying is for arcs. I was just tired of having to pick each arc when I could make them into a polyline and do the same thing.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    It depends on what kind of object you are calculating, line , arc, ellipse . . .
    Here is a way point :
    (setq Ent (entsel "Select the polyline curve : " ) )
    (vl-load-com )
    (setq VlaObj (vlax-ename->vla-object (car Ent )) )
    (setq MyDist 250 ) ; <-- Your distance input
    (setq Param (vlax-curve-getParamAtDist VlaObj MyDist ) )
    line :
    (setq Ang (- (* (/ (Angle (vlax-curve-getFirstDeriv VlaObj Param ) (vlax-curve-getSecondDeriv VlaObj Param ) ) pi ) 180 ) 90 ) )
    arc :
    (setq Ang (- (* (/ (Angle (vlax-curve-getFirstDeriv VlaObj Param ) (vlax-curve-getSecondDeriv VlaObj Param ) ) pi ) 180 ) 45 ) )
    : ) Happy Computing !
    kennet
    2002-01
    jUSt Here (a lot)
    8,747
    Quote Originally Posted by kennet.sjoberg
    (vl-load-com )
    line :
    arc :
    kennet
    Thanks kennet. That gives me something to work with. Why is the arc at 45 degrees instead of 90 degrees?
    2002-05
    1,707
    Quote Originally Posted by Opie
    That confuse me to, and I do not really know why, but for me it works that way. . and then you have the ellipse.
    You have to test before you permanent the code, I may be wrong in this case.
    kennet
    2000-09
    Chelan WA
    1,059
    The first derivative will give the slope at any point on a curve that is continuous, but in the case of a vertex, where the curve is not continuous, it will not. One suggestion is to use the vlax-curve-getpointatdist function to get the point 0.001 in front of your point and 0.001 behind your point and then calculate the angle between the two and then add pi/2 to get the angle of your perpendicular line. Using the polar command it would be easy to draw the line.
    Another way is to determine the slope of one segment using the derivative and the slope of the next segment using the derivative and then average them and then add pi/2.
    Peter
    2002-01
    jUSt Here (a lot)
    8,747
    Thanks kennet. Hopefully with this routine I won't need to worry about an ellipse since we don't use them very often.
    Thanks for the insight, Peter. That explains it a little more. I am still confused with it but I'll figure it out with time.
    Both of you are an asset.
    Richard
    2004-02
    Colorado
    1,986
    WARNING: vlax-curve-getSecondDeriv returns 0 for lines and line segments.
    2004-02
    Colorado
    1,986
    Quote Originally Posted by peter
    Peter
    This is a little confusing, but it raises a valid point.
    I don't think Peter means "continuous" - by definition, a polyline must be continuous. But for a polyline, the derivatives at each vertex are based on the following segment of the polyline (the "course out" of the vertex, so to speak). So a problem arises when there is an angle point at the vertex (i.e., the "course in" and the "course out" of the vertex are different).
    As an example, assume you have a polyline with a bunch of line segments (no arcs). The first derivative at param=4.0 would be the same as the first derivative at param=4.01, but not the same as the first derivative at param=3.99. If the segment between param=4.0 and param=5.0 is an arc segment, the derivatives at param=4.0 yield tangent and radial vectors at the beginning of the arc segment. But in either case, the derivatives at param=4.0 are for the "course out", or the segment between param=4.0 and param=5.0. The only way to determine the values for the "course in" is to get the derivatives at a point where the param<4.0 by just a hair.
    So, Peter's method will split the difference between the "course in" and the "course out", which may or may not be exactly what you want. The only thing I would add is you may want to make sure you calculate points around your vertex using distance methods, and not parameters. For polylines, the distance between parameters varies, depending on the length of the polyline segments.
  1. Fillet perpendicular lines
    By Raudel Hinojosa Sr in forum AutoLISP
    Last Post: 2015-08-07, 06:40 AM
  2. Looking for routine...Polyline box around a polyline
    By iacevedo270202 in forum AutoLISP
    Last Post: 2011-04-06, 06:20 PM
  3. Extension Lines on Arc Length Dimension Always Perpendicular
    Last Post: 2009-02-01, 05:08 PM
  4. Drawing perpendicular to a 3D polyline
    By sbullinger in forum AutoCAD General
    Last Post: 2008-08-15, 07:14 PM
  5. Non-parallel/perpendicular grid lines
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2006-11-16, 07:22 PM
