Thread: Property lines: how to subdivide?
    2004-06
    Memphis TN area
    7,048
    Default Property lines: how to subdivide?
    I have an AutoCAD file of a site survey, showing property lines with distances and bearings. The overall site is sort of a rectangle, with a property line passing down the middle, dividing the property into 2 lots. The distances and bearings shown are for the outside property lines, but it doesn't give me any distances for the subdividing line from the outside corner.
    So I created the overall property using a table, inputting the values shown on the survey. Now if I draw the subdividing line, it says it's not closed and area will not be computed. What would be the best way to go about this? I don't guess there would be a way to add the subdividing line in the table. I'm guessing I would probably just end up having to make 2 separate areas with one side of each overlapping. If that's the case, how could I show a total area of the whole property?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Property lines: how to subdivide?
    Create two new lots, by sketching, directly over the existing property lines, dividing the lot as shown. Then delete the original.
  1. property lines
    By jmiller.159389 in forum Revit - Platform
    Last Post: 2008-05-21, 03:46 PM
  2. Setback Lines with Properties Like Property Lines
    By cwilrycx.109927 in forum Revit Architecture - Wish List
    Last Post: 2007-06-12, 04:34 PM
  3. Property Lines
    By brd in forum Revit Architecture - General
    Last Post: 2006-07-20, 08:56 PM
  4. Property Lines
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2005-02-03, 05:32 AM
  5. Property Lines
    By Urban D in forum Revit Architecture - General
    Last Post: 2003-08-08, 01:31 AM
