Results 1 to 9 of 9
Thread: Interior Elevations w/ Irregular Outlines?
    Member rebecca's Avatar
    2006-01
    8
    Default Interior Elevations w/ Irregular Outlines?
    How do I show an interior elevation if the interior of the room is not rectilinear--for example, if the ceiling is sloped? Otherwise the interior elevations just look like sections.
    Also, is there a way to make the outline of the elevation a thick line, regardless of what object is being cut?
    Currently I have been using the invisible line tool to get rid of undesired lines that remain within the rectangle of the crop region, and then adding Wide drafting lines onto my sheets over the perimeter of the elevation--certainly very low tech.
    Revit Mararishi aaronrumple's Avatar
    2002-02
    St. Louis, MO
    4,695
    Default Re: Interior Elevations w/ Irregular Outlines?
    Quote Originally Posted by rebecca
    You'll find a white filled region with a hole it a little faster than the linework tool. Make the pattern of the white filled region "No Pattern" so that it exports cleanly to AutoCAD. The linework of the "hole" can be a bold lineweight.
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    The subject of Revit interior elevations has come up many time before. Check out this post...
    http://forums.augi.com/showthread.php?t=2669
    100 Club Fred Blome's Avatar
    2003-05
    Palo Alto, California
    143
    Quote Originally Posted by aaronrumple
    Here's a Detail Component for the outline & white region. It might save a bit more time, tho' of course it is rectilinear.
    Member ToddVB's Avatar
    2004-05
    15
    Unhappy Re: Interior Elevations w/ Irregular Outlines?
    Wouldn't a simple solution to this issue be to have the ability to control the crop region line weight? Basically if you could adjust the line weight you could make it a appear with a heavy outline. I've looked up and down in this program and cannot find a way to do this.
    The Outline frame may be a patch solution, but is still a pain. With software that is as powerful as Revit the user should not have to spend valuable time on trivial tasks that can more or less be automated.
    2004-08
    183
    We use both the linework tool and the filled region method - both really stink. I agree that if they just gave us the ability to change the lineweight of the crop region the problem would be solved. plus the ability to change the shape of the crop region (edit/sketch mode).
    Finger's crossed.
    I could stop if I wanted to jspartz's Avatar
    361
    I can't believe this has been overlooked for at least 4 years since the issue was brought up. This could be fixed so easily, but just putting crop regions in the object style list and making a sketch feature for adjusting the shape. I personally feel like getting Autodesk on the line.
    2003-04
    Chino, CA
    4,756
    Quote Originally Posted by jspartz
    You should. The development team works in part from formal requests for features made by submitting a "Support Request" from Revit. If you want something, you have to let them know. Calling would be ok, but a support request puts it in writing and makes it accountable.
    361
    I put in my suggestions to Autodesk:
    There are three things I would like to see done with crop regions.
    First, crop regions should be in the visibility settings to be able to adjust the lineweight so that people don't have to outline each individual interior elevation with thick lines like everyone using this program is doing.
    Second, crop regions should be able to be modified so they don't have to be rectangular, maybe with a sketch tool for editing them. Right now, people are creating solid white filled regions to blank out areas because the crop region can't be adjusted.
    Third, crop regions should be able to be temporarily turned off, so that you can see everything that is in the view, work on it, and then turn it back on. To work on something I pulled off to the side, I have to stretch the crop region out, losing my spot, and then stretch it back to the closest spot I remember it was at. I would like to just temporarily disable it and then enable it.
  1. interior elevations
    By jessica.146534 in forum Revit Architecture - General
    Last Post: 2010-01-06, 08:50 PM
  2. A B C D on interior elevations
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-08-01, 03:25 PM
  3. Interior Elevations - Cut Box?
    By jtl in forum Revit Architecture - General
    Last Post: 2007-10-26, 04:17 PM
  4. Where is Interior Elevations?
    Last Post: 2005-12-06, 06:50 PM
  5. interior elevations
    By neb1998 in forum Revit Architecture - General
    Last Post: 2005-06-21, 05:45 PM
