Results 1 to 10 of 15
Thread: Unable to select inserted Word file
    ATP Recruiter CAD Dawn's Avatar
    2005-10
    Smiling and Nodding
    88
    Default HELP!!!! Please!!!
    OK, I know this is in the wrong forum and I'll erase it when I'm done, but please help!!
    A consultant has inserted a Word file into one of our drawings and made it unselectable. I haven't inserted anything from Word in so long (I insert Excel stuff using Spanner) so I don't remember how to fix it. The architect is on the East Coast (so he's not at work) and I need to finish this before I go home.
    Please help!!!
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Default Re: Unable to select inserted Word file
    If it is an OLE object, try this thread. http://forums.augi.com/showthread.php?t=13638If it's inserted as an image make sure imageframe is set to 1.
    Still trying to find out "Who is a good boy?"
    2002-01
    Orlando, FL.
    1,348
    This is a shot in the dark but have you tried to audit the drawing? Are you sure it's an OLE object and not an image?
    2002-01
    Orlando, FL.
    1,348
    Make sure all your layers are "on" and not locked.
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    2
    Red face Re: Unable to select inserted Word file
    Hi!
    Forgive me if I am repeating anything you have already tried, but did you type in OLEFRAME? It should be set to 2. If it is set to 0, you will not be able to select it.
    I hope this fixes your problem.
    Best regards,
    Teresa Martin
    Ideate Inc
    2005-10
    Smiling and Nodding
    88
    Quote Originally Posted by Teresa.Martin
    Hi!
    Best regards,
    Teresa Martin
    Ideate Inc
    Thank you! OLEFRAME is an unknown command...is it new for 2006? I'm running 2004.
    2005-10
    Smiling and Nodding
    88
    I audited. All layers are on, none are locked.
    2002-01
    Orlando, FL.
    1,348
    Quote Originally Posted by CAD Dawn
    Is it in paperspace?
    2005-10
    Smiling and Nodding
    88
    Talking Re: Unable to select inserted Word file
    Quote Originally Posted by Augi Doggie
    Si...I can OLEHIDE it, but I want that bad boy gone!
    Love your hair, hope you win!
    2004-11
    438
    Try Ole2frame instead. Yes, I am using Autocad 2006, but let me try it in 2000i...Yep, I guess it is new.
    However, you can try this method for getting rid of it. It is from the Autodesk website.
    Here is the link:
    http://usa.autodesk.com/adsk/servlet...linkID=2475323
    The white paper id from the support site is: TS64541
    Best regards,
    Teresa Martin
    Ideate Inc
  1. Replies: 2
    Last Post: 2012-07-04, 07:40 AM
  2. Unable to select or manipulate Objects from a .DXF file
    By snorcisa in forum AutoCAD General
    Last Post: 2007-03-02, 05:24 AM
  3. Replies: 7
    Last Post: 2007-01-19, 04:01 PM
  4. Unable to select OLE (eg Excel) Objects within drawing file
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-26, 07:05 PM
  5. Cannot select centerline reference of an inserted family object
    By Haden in forum Revit Architecture - Families
    Last Post: 2004-09-17, 09:48 PM
