residarchitect
Henry, I liked your siding. As siding its great. I did a real log cabin
using real logs in Autocad. I found that it was not a typical structure
in any way. Logs in compression shrink a huge amount. I had to
plan for an 8+ inch shrinkage in the height of the building over a 6
year period. To accomodate the shrinkage, I had to put columns on
adjusting jacks, I had a stair design that had to eventually be able to
loose a whole riser, I had window and door heads that had the 8+
inch spacer below lintel/headers, I had mechanical system piping with
adjustable flanges, I had crown molding around the interior walls on both
sides to hide the wall gap for the ultimate shrinkage. These are only
a few of the headaches.
Also, in real wood log cabins the logs interlink at end points rather
than wrap as you drew. I like the log cabin look you achieved and given
that it could use conventional construction so much the better.
