I know there is a way to do this but I am not sure what commands I should use. I know it would be some (vlax-XXX) command or the souch but I am not to familiar with those can someone point me inthe right direction?
I want to insert a block into a drawing. But here is the hard part. These blocks change on a weekly basis. I want to scan a file and if the block I am looking for is there I want to insert that block if it is not there then I want to insert the block from my archive set.
basically
(if
(test to see if block in source drawing) ;test
(insert block from source);then
(insert block from file);else
);if
