Summary: A construction note manager that would work within the sheet set manager.
Description: I would like AutoCAD to create a Construction Note Manager that would work within the Sheet Set Manager.
How Used: I would use the Construction Note Manager to manage construction notes for a set of plans. There would be construction note templates on the network to choose from, such as County of Riverside Street Improvement or Eastern Municipal Water District. Once the template has been inserted into the sheet set you could turn on/off notes to compile a complete list of notes needed. New notes could be added as necessary and the complete list could be rearanged and subsequently renumbered. The complete list would appear on a particular sheet and could include quantities. Each plan sheet would include only the notes that relate to that sheet based on construction bubbles that have been placed in model space. As the notes change or renumber in the complete list they would change in the plan sheets. As construction bubbles are added or removed in the plan sheets the list of notes within that sheet would update. Naturally there would be a need to be able to format the construction note table for the different regions' drafting standards including attaching construction bubbles as part of the construction note table.
Feature Affinity: Sheet Set Manager
Submitted By: Mike Anderson on February 3, 2006
