Thread: DWF Viewer 6.5 Functions in DWF Composer 2.0
    Member james.emoore's Avatar
    2005-06
    19
    Default DWF Viewer 6.5 Functions in DWF Composer 2.0
    My company has had a DWF Comper 1.0 for several months. When the new DWF Viewer (6.5) came out in late November, we got the update and installed it. On machines that had DWF Composer, the new functions (i.e. cutting sections in 3D DWF files) were available in composer after the viewer update.
    We recently upgraded our DWF Composers to release 2.0. When we completed the first install of the 2.0, the functions from DWF Viewer 6.5 were no longer available. I have tried re-installing the Viewer update, but that did not seem to work.
    Has anyone else experienced a similar issue when upgrading or have any suggestions?
    [James E. Moore, RA (US-IA)
    SchenkelShultz Architects
    I could stop if I wanted to scott.sheppard's Avatar
    2005-07
    Scottsdale, Arizona
    239
    Default Re: DWF Viewer 6.5 Functions in DWF Composer 2.0
    When Autodesk DWF Composer R1 was out, followed by Autodesk DWF Viewer 6.0, a user could install DWF Viewer 6.0 and the new functions would appear in DWF Composer. This was because the new functions were implemented in some libraries that were shared among the two products.
    I have Autodesk DWF Composer R2 on my system. I had hoped for a repeat performance when Autodesk DWF Viewer 6.5 came out. Not so. The new functionality involves UI in the DWF Viewer itself - not just the common libraries. For now I have both products on my system. I normally use Autodesk DWF Composer as my default for the Open Command. When I want to use sectioning or pull apart on a DWF, I use the right-click "Open With" and select Autodesk DWF Viewer.
    Autodesk DWF Composer R3 (which will be called Autodesk Design Review) will rectify the differences between the products.
  1. Replies: 0
    Last Post: 2012-11-24, 07:38 PM
  2. 2011: Mur Composer
    By lucos in forum Revit Architecture - Général
    Last Post: 2011-02-14, 04:46 PM
  3. Replies: 2
    Last Post: 2006-11-27, 04:43 PM
  4. Composer vs. Viewer Functionality
    By Dimitri Harvalias in forum Design Review - General
    Last Post: 2005-12-14, 02:51 AM
  5. DWF Composer & DWF Viewer
    By Beth Powell in forum Design Review - General
    Last Post: 2004-10-06, 01:04 PM
