Results 1 to 10 of 12
Thread: Dimensions on the correct layer
    ACAD Wish List Administration
    1,920
    Default Dimensions on the correct layer
    Summary: An option to place all dimensions on a user defined layer, eliminating the need to change layers when dimensioning an object.
    Description: Placing Dimensions on a given layer has always been on task we all dread trying to remember.
    A button in the Dimension Dialog Box would allow all Dimension to be placed on a given layer.
    But just like dimensions they would allow for an override.
    W. Kirk Crawford
    Rochester Hills, Michigan
    How Used: Allow a check box for Dimensions to be on a given layer, and then key-in that layer name, or allow a pull-down from the Layers Manager.
    But allow for Overrides.
    Feature Affinity: Dimensions
    Submitted By: Kirk Crawford on February 5, 2006
    2006-02
    25
    Default Re: Dimensions on the correct layer
    Change your command macro under the "Customize User Interface" to something like this,
    *^C^C-layer;set;A_dims;^C^C_dimlinear. The asterisk in front keeps the command going until you key in escape.
    2005-09
    88
    We use the tool palettes for this - although we don't have the override option (what did you want to override - the layer?) The tool palette option imports the dimension style, and child styles, as appropriate, from a source file, and puts them on the appropriate layer. Its a very powerful function, available to you now.
    2004-10
    12
    you could possibly write a lisp code fragment To change dimensions "The morning after"
    but To allow for certain dimensions To be on "alternate" layers you might have To define more Than one dimension style
    (defun c:chg-dims ()
    (setq dimx (ssget "x" (list (cons 0 "dimension") (cons 2 "dimension-style-name")))))
    (entmod (assoc 8 <The "whatever-current-layer-name"> <To The "intended-layer-name">))
    you could set This up To ONLY LOOK for The dimensions That do NOT have The "alternate-named-dimension-style"
    ok not exactly correct, )); but a sketch of an idea
    i am not sure how To filter dimension-style-names
    but i assume it is possible
    just an Idea
    Randy
    Member Seattlemander's Avatar
    2006-03
    Seattle, of course!
    6
    Actually, I think this is a great idea. I reject the idea that "you could write a lisp routine". This is true for just about everything. The idea is to take ideas that people think are useful, and make them part of the program.
    150700
    3,439
    Quote Originally Posted by kuempel.s
    Yes, but it is also perfectly acceptable to offer a work around.
    Remember, the only way to make these wishes reality is to vote when the time comes!!!
    2006-03
    Seattle, of course!
    6
    Talking Re: Dimensions on the correct layer
    Quote Originally Posted by BrenBren
    Right, you are! And, Randy's idea is good. I just got greedy thinking of permanent enhancements. My response was meant to be much less jerky than it reads.
    150700
    3,439
    Not a problem
    2005-07
    29
    Exclamation Re: Dimensions on the correct layer
    Not every dimension ends up on the same designated layer. There could be a dozen layers intended for dimension objects on one building plan.
    9,805
    Quote Originally Posted by Seattlemander
    This is part of the program -> Tool Palettes. No lisp programming required.
  1. Correct Dimensions in 3D or Iso Views
    Last Post: 2008-10-11, 09:09 PM
  2. Correct Display of Ordinate Dimensions
    Last Post: 2007-11-08, 04:38 PM
  3. Replies: 4
    Last Post: 2006-12-11, 06:34 PM
  4. Draw Viewport on correct Layer then switch back to original Layer
    By steve459238 in forum AutoCAD Customization
    Last Post: 2006-11-11, 12:03 PM
  5. Section dimensions not displaying on the correct plane
    By Spectrefish in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-04-29, 06:01 PM
