Thread: Server error codes relating to datasource connectivity
    2006-08
    Post Server error codes relating to datasource connectivity
    Good Morning one and all.
    I'm having problems trying to locate a list of error codes and troubleshooting information for the application.
    I've received an error 530 - 684 which relates to datasource connectivity.
    I simply cannot find the information required on the Autodesk homepage and so decided I would visit here and see if anyone could assist me by providing this information? Surely Autodesk must publish this list to assist IT Ops in the day to day running and troubleshooting of said application ?
    Any information you can give would be great.
    Kind Regards
    NPrytherch
    13,656
    Question Re: Server error codes relating to datasource connectivity
    Hi
    Have you tried browsing / searching the Autodesk MapGuide Support area on the Autodesk web site...
    Have a good one, Mike
    2006-08
    Unhappy Re: Server error codes relating to datasource connectivity
    Hi Mike,
    Yes I have tried searching their support site for the product and it is well... as useful as a chocolate T-Pot, hence why I've posted here, figured the users here may have had exposure to these kinds of problems before and so may know where to find the information to troubleshoot.
    Regards,
    NPRYTHERCH
    Member sdaniel.3467's Avatar
    Sussex, Wisconsin
    26
    Default Re: Server error codes relating to datasource connectivity
    NPrytherch,
    Can you provide more detail about the error you are getting? Is this a secondary data source connection or something else?
    Scott D. Daniel
    GIS Analyst
    Ruekert · Mielke
    W233 N2080 Ridgeview Parkway
    Waukesha, WI 53188
    (262) 542-5733
    (262) 542-5631 Fax
    sdaniel@Ruekert-Mielke.com
    http://www.ruekert-mielke.com
    2006-08
    Thumbs up Re: Server error codes relating to datasource connectivity
    Certainly... the error is:
    Autodesk MapGuide Server error: 530 - 684
    Unable to retrieve data for layer "Label Present Position". The server failed to fetch data from the datasource *datasource name*.
    Then it lists all fields and values.
    This is a strange error and to be honest I cannot believe that it is so hard to find information on such a large product and its error codes, why else would an error code be created if not to assist in the resolution of faults and errors.
    13,656
    Hi
    Am I correct in assuming the following post on the Autodesk Discussion Groups "Autodesk MapGuide belongs to yourself and is dealing with the same issue / problem...
    Random Server Error 530 - 684
  1. Replies: 2
    Last Post: 2013-08-08, 05:52 PM
  2. R6025 error message with vb.net codes
    By t_khoshzaman in forum Dot Net API
    Last Post: 2010-07-28, 08:52 AM
  3. Что за процесс в Inventor Connectivity.EDMWS.Server.exe?
    By pernuel in forum Русский - Inventor
    Last Post: 2010-01-23, 04:43 AM
  4. Autodesk Map 3D 2007/ArcSDE 9.1/SQL Server connectivity
    By mitzip in forum AutoCAD Map 3D - General
    Last Post: 2006-07-20, 05:29 PM
