Results 1 to 6 of 6
Thread: Problem Running Excel From AutoCAD Shell Command
    2015-09
    420
    Default Problem Running Excel From AutoCAD Shell Command
    Hello to All AUGI Members:
    I had a lisp routine that used the shell command to run Excel opening a specified file. The IT department changed tha install path for the Excel.exe file to a location that has spaces in the path such as C:\Program Files\Microsoft Office\Office11\Excel.exe.
    Beacuse of the spaces my program will not run Excel with the specified file. Below is a sample of the lisp code that I am using:
    #######SAMPLE CODE
    (defun c: Dexcel (/ )
    (SETVAR "CMDECHO" 0)
    ;;;This is the old path that worked OK
    (command "shell" "P:\\SHARED\\OFFICE\\PFILES\\MSOFFICE\\OFFICE\\EXCEL.exe H:\\cad4\\support\\Test-Excel.xls")
    ;;;This is the new path that does not work
    (command "shell" "C:\\Program Files\\Microsoft Excel\\Office11\\Excel.exe H:\\Cad4\\support\\Test-Excel.xls"
    (SETVAR "CMDECHO" 1)
    (princ)
    Is there a way to protect the path that contains the spaces.....??
    Any assistance would be appreciated.
    Regards,
    Vince
    2004-08
    Iron Station, NC
    3,198
    Default Re: Problem Running Excel From AutoCAD Shell Command
    try using / instead of \\
    or the old dos way -> c:\\progra~1
    2015-12
    Central Oregon
    591
    Hi Vince,
    you need to get the path enclosed in quotes:
    "\"C:\\Program Files\\Microsoft Excel\\Office11\\Excel.exe\" H:\\Cad4\\support\\Test-Excel.xls"
    HTH,
    Jeff
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Have a look at this thread (STARTAPP ???). I think it will be helpful.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Replace the old shell stuff :
    (command "shell" "C:\\Program Files\\Microsoft Excel\\Office11\\Excel.exe H:\\Cad4\\support\\Test-Excel.xls" )
    with :
    (startapp "C:\\Program Files\\Microsoft Excel\\Office11\\Excel.exe H:\\Cad4\\support\\Test-Excel.xls" )
    : ) Happy Computing !
    kennet
    2015-09
    420
    Jeff, Ken, Opie, Chris:
    Thank you for your quick response........Your recommendations provided a good solution for me and works fine in my environment.
    Once again I would like to thank everyone for your assistance.....!!!!
    Regards,
    Vince
  1. Replies: 5
    Last Post: 2013-10-16, 05:39 PM
  2. Windows XP - problem running Autocad 2008 on a XP virtual machine
    By radin.hairul.anwar in forum Operating Systems
    Last Post: 2008-05-14, 09:25 AM
  3. Replies: 6
    Last Post: 2007-01-08, 01:12 PM
  4. Old DOS Shell Command
    By eschwartz in forum AutoLISP
    Last Post: 2005-10-31, 06:03 PM
  5. problem running AutoCAD Mechanical 2004
    By iffans in forum AutoCAD Mechanical - General
    Last Post: 2004-12-05, 06:12 AM
