Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: When copying certain Blocks certain Objects loose their Display Order
    2006-02
    20
    Default When copying certain Blocks certain Objects loose their Display Order
    When copying certain blocks certain objects loose their display order
    2001-12
    St. Louis
    5,408
    Question Re: When copying certain Blocks certain Objects loose their Display Order
    Quote Originally Posted by r_soula
    does this help? ID: TS50845 - DRAWORDER command does not work in xref drawings
    (see below under 'similar threads' feature)... I realize this says x-refs, but, from what I understand from what I read, it is affected after you bind the ref, turning it into a block
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2006-02
    20
    Default Re: When copying certain Blocks certain Objects loose their Display Order
    I have and instrumentation block with lines in it that always go behind the hatch.
    I can copy it all over the place if i start from scratch
    But if I use it other than from when I start a dwg from scratch it looses its DR
    I wouldn't think that would have anything to do with xrefs
    13,656
    Hi
    What happens if you use the command _.RegenAll ?
    Is correct DrawOrder restored ?
    Have a good one, Mike
    2006-02
    20
    Unhappy Re: When copying certain Blocks certain Objects loose their Display Order
    Problems still accurs with regen all
    Yes it is
    13,656
    Hi
    Sorry, I am a little confused here ( your responses to my above questions, shown in blue below )...
    What happens if you use the command _.RegenAll ? Problems still accurs with regen all
    Is correct DrawOrder restored ? Yes it is
    Please clarify.
    2006-02
    20
    Sorry,
    Yes, that is the case
    13,656
    Hi
    Is it possible to post an example of a Block that exhibits this behaviour ie Loses it's DrawOrder when Copying.
    2006-02
    20
    How do you post a block?
    13,656
    Hi
    Try here...
    What Are Attachments?
    If still no luck, please post back ( I will then try to explain some more ).
  1. 2012: Display Order for objects
    By rbhazie in forum AutoCAD General
    Last Post: 2015-03-20, 12:43 PM
  2. Display Objects That You Are Copying While They Are Being Located
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-10-23, 10:15 PM
  3. 2012: Display Order of Objects Drawn in Paper Space
    By Viswaprakash in forum AutoCAD General
    Last Post: 2011-12-20, 06:49 AM
  4. 2011: Modeled Objects Display Order
    By ekonski319518 in forum Revit Architecture - General
    Last Post: 2011-07-25, 07:34 PM
  5. Replies: 4
    Last Post: 2006-11-30, 03:25 PM
