Thread: Block attribute extraction to an AutoCAD Table
    2004-06
    8
    Default Block attribute extraction to an AutoCAD Table
    Is it possible to extract block attribute information to an AutoCAD table.
    13,657
    Default Re: Block attribute extraction to an AutoCAD Table
    Hi
    Please note I have *moved* this thread from the AutoCAD General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,657
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TP5564831 - Extracting block attributes to a table
    2 Undocumented AutoCAD 2006 Commands
    Have a good one, Mike
  1. 2012: Block attribute extraction
    By dave.moorcroft167897 in forum AutoCAD General
    Last Post: 2012-10-14, 05:28 PM
  2. Block Attribute Table Values Dont' Appear in Block
    By stusic in forum Dynamic Blocks - Technical
    Last Post: 2011-12-27, 02:58 PM
  3. Attribute Value extraction into Table Field
    By steven_mott33 in forum Dynamic Blocks - Technical
    Last Post: 2010-09-04, 10:25 PM
  4. Insert Blocks into a Table via Attribute Extraction
    By martin.99248 in forum AutoCAD Tables
    Last Post: 2007-12-01, 06:04 PM
  5. Title Block Attribute Extraction?
    By mcoffman in forum VBA/COM Interop
    Last Post: 2006-03-14, 08:18 PM
