Thread: Program?
    2006-01
    2
    Default Program?
    Does anyone know of a program where I can do this: Set up a templete either in a raw data file or field book file that when the survey crew can shoot a cross section of a street then shoot just one point lets say flowline and the rest of the line work can connect to there corresponding locations based on the cross section that was shot at the beginning. Thank you.
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,444
    Default Re: Program?
    It sounds like you want to create cross sections based on a feild shot for plotting? If you have Civil esign, you can do this using a template and setting the Reference point to be the Feild shot you want the survey crew to shoot. Then create your profile using those shots and process the sections using your template.
    Earth
    9,803
    Quote Originally Posted by jhernandez.104188
    You don't indicate what software you are using, but all the Carlson products can do this.
    R.K. McSwain | CAD Panacea |
    2006-01
    2
    My company is using LDD 2005 at the moment but are looking to potentially purchase software that can do this. I have a trial version of Carlson SurvDesktop. Not seeing where I can do this in the manual that comes with the software. Can anyone point me in the right direction. Thank you
    Earth
    9,803
    Look in the Field to Finish routine. Call the FREE support line if necessary 1-800-989-5028
  1. Program need
    By cadd4la in forum Dot Net API
    Last Post: 2013-12-20, 06:13 AM
  2. Program need
    By cadd4la in forum VBA/COM Interop
    Last Post: 2013-12-13, 12:21 PM
  3. Which Program would be right for me...
    By Matt H in forum 3ds Max - General
    Last Post: 2007-08-20, 03:17 PM
  4. Writing a Short program from Large Program
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-07-13, 01:26 AM
