Results 1 to 7 of 7
Thread: Updating Sheet Set preview
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Updating Sheet Set preview
    Hi all,
    Has anyone found out how Sheet Set previews can be updated? I've tried removing & re-importing, but that doesn't work.
    kwong
    13,656
    Default Re: Updating Sheet Set preview
    Hi kwong
    Please note I have *moved* this thread from the AutoCAD 2006 General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    I think you might be out of luck ( though I am pretty sure there must be some method of getting it to work; just need to find that method )...
    Updating Preview thumbnail image in sheet sets
    preview thumbnails in sheet set manager
    Have a good one, Mike
    2002-11
    270
    Thanks Mike,
    I did do a search, but was hoping someone had found the answer in the meantime. Hope someone will soon.
    kwong
    100 Club avdesign's Avatar
    2005-08
    STL Metro
    173
    I've noticed at least on 2006 the previews are updated when you save.
    2002-11
    270
    Gday avdesign,
    I'm using 2006 and it doesn't happen; however, I've just found that if I saved the drawing while in a different tab, eg the model tab, exit ACAD, and re-open, the preview is updated. Maybe I've got different settings somewhere to yours.
    2008-09
    Hi all,
    The problem is solved by adjusting your drawing limits to fit the whole area of your titleblock. You can do it individually that is open each drawing and make the necessary chages or change the template's limits you're using to create sheets in your sheet set manager.
    Hoping that this helps you,have a good day.
  1. text in plt preview jumbed all over the sheet
    By nevergowith18839042 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-03-08, 07:11 PM
  2. Sheet Set Updating
    By JamminJim in forum AutoCAD Sheet Set Manager
    Last Post: 2008-10-22, 05:23 PM
  3. Field created in 2008 not updating in 2007 print preview
    By njohneer in forum AutoCAD Fields
    Last Post: 2007-08-31, 02:38 PM
  4. Updating Preview thumbnail image in sheet sets
    By mf in forum AutoCAD Sheet Set Manager
    Last Post: 2006-09-13, 04:54 PM
  5. Sheet 1 of 1 as updating feature to a Master Sheet Set template
    By avdesign in forum AutoCAD Sheet Set Manager
    Last Post: 2006-01-20, 12:14 PM
