I have a drawing with several object data tables, when I go to the Map pull down, tools, convert object data to database links. In the target Link Template, Data Source: " jet_dbsamples" is the only selection available. Then in Table Name: I select my table and go through the remainder of the dialog box. When I select proceed i get a warning that conversion failed, select ok I then get a window with error info" ASI Error : 538642193 - Cannot modify the design of table 'My table Selection Name'. It is in a read only database. I have looked through my table designs, options, etc. and can not find anyplace to reset tables to read/write status or anyway to export object data tables out of my drawing file. I had even previously tried using Mapguide SDF loader to export layer with related object data table and got error that data tables were not available.
Anyone got any ideas how to get this data out of the drawing?
Any thoughts or ideas will be greatly appreciated.
