Results 1 to 7 of 7
Thread: Field gives me square units (meters), but I need hectare (=Sq.Meters/.0001)
    Cool Field gives me square units (meters), but I need hectare (=Sq.Meters/.0001)
    Ok i have a field that is giving me square units (meters) and i need to show hectare (=Sq.Meters/.0001). The fields have a sq.Ft.
    Is there a field or a units change that i can change. or maybe a lisp routine that works well. i have about 80 areas that i need to change and i don't really want to change them on the calculator and then type them out for each text box.
    Really appreciate any suggestions. Thanks
    Pedro Gastelum Jr.
    CAD Tech
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,082
    Default Re: Field gives me square units (meters), but I need hectare (=Sq.Meters/.0001)
    Quote Originally Posted by pgastelum
    You can place a formula into a field. Within the field command, first select the Objects field category. Then select the formula option. In the formula box (lower middle right side), right click to insert another field. Within the new field you would select the object you want to get the area from. Press OK to return to the original field dialog box to continue with the formula.
    HTH
    2002-01
    jUSt Here (a lot)
    9,082
    Please note I have *moved* this thread from the Autolisp Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Richard
    Forum Moderator
    2000-01
    Seattle WA USA
    5,859
    Note that is only available in 2006 or later. 2005 did not have that option.
    2015-08
    birmingham, alabama
    131
    hi,
    try this as a different option (possibly in a lisp routine)
    (print (cvunit 10000 "centares" "hectares"))
    in your routine substitute a user variable for the 10000.
    (a centare is a square meter)
    karl
    Thanks guys I used my co-worker's 2006 version and it was just a matter of modifying the fields.
    Thanks for all your suggestions.
    Pedro Gastelum Jr.
    CAD Tech
    2002-01
    jUSt Here (a lot)
    9,082
    Good to hear you got it working. Thanks for posting back.
  1. 2012: Data Connect SHP (meters). Need to view in Imperial AutoCAD units.
    By fairhilleng in forum AutoCAD Civil 3D - General
    Last Post: 2014-01-15, 11:37 AM
  2. 2010: Command Line - display units in meters
    By arifut879238 in forum AutoCAD General
    Last Post: 2012-06-07, 07:23 PM
  3. Electric Meters
    By Sevans-MEP in forum Revit MEP - Families
    Last Post: 2010-02-23, 03:04 PM
  4. Levels in meters
    By peter.giampa in forum Revit Architecture - General
    Last Post: 2009-04-02, 03:02 AM
  5. meters and milimeters
    By pba7 in forum Revit Architecture - General
    Last Post: 2006-05-04, 12:29 AM
