Originally Posted by
huuthu_nguyen
I 've got back a dwg from a guy who has AutoCad Mechanical and had opened the trouble dwg that I post earlier, then saved back to dwg. (as attached 1.1 Test.dwg).You will find the missing proxys appears every where as compare with the one earlier. Still I have no idea why the first one did not show all the proxys.( As you can see that the first one when I try to delete other sheet to reduce the file size, the proxys were hidden hence they were not deleted.Now I have just deleted futher,bottom sheet to reduce the file size futher.)
