Thread: Find string in drawing and replace with VBA
    2006-02
    10
    Default Find string in drawing and replace with VBA
    I'm trying to create something that will find a particular text object based on its string, and replace it with a variable value.
    For example...
    I've got a table (on PaperSpace) of calculations for area square footages. It would look something like this:
    Total coverage........SQcov
    Livable...................SQliv
    Exterior..................SQext
    The "SQxxx" are all basic text objects. I already have a working function that uses the geometry in the drawing (ModelSpace) to automatically calculate the appropriate values, and now I want to simply replace the text string "SQxxx" with the value of the variable containing the appropriate calculated area.
    I also have several different PaperSpace layouts, but I know exactly which one each string is on, so I can easily specify that if necessary. I'm not even sure if that matters..
    Anybody know how I can do this? I'm fairly new to VBA still.
    --Montana
    2000-01
    Seattle WA USA
    5,859
    Default Re: Find string in drawing and replace with VBA
    You failed to mention what version of AutoCAD... fields in 2005 or later will does this already.
    2006-02
    10
    Sorry, I'm using ADT 2004.
    2000-01
    Seattle WA USA
    5,859
    The brute-force approach would be to get the layout, then loop thru the objects until you find the needed string.
    You can get the Layout object:
    Set myLayout = ThisDrawing.Layouts.Item("Layout1")
    Once you have that, iterate thru the Layout.Block until you get to the text object.
  1. how to replace only a single string by pre decided string.
    By mohammad.raees637333 in forum AutoLISP
    Last Post: 2014-04-22, 01:07 PM
  2. How do I replace part of a string?
    By aaronic_abacus in forum AutoLISP
    Last Post: 2009-12-12, 06:24 PM
  3. Find and/or Replace Text in the Drawing Manager
    Last Post: 2009-10-25, 03:34 PM
  4. Replies: 0
    Last Post: 2008-05-22, 08:49 PM
  5. find and replace removing first letter string
    By tyeelaw13 in forum AutoCAD General
    Last Post: 2005-05-03, 04:20 PM
