Thread: Closing AutoCAD with project opens causes fatal error
    2006-01
    Default Closing AutoCAD with project opens causes fatal error
    Hi
    My project is plugin with autocad i.e i placed an icon on the tool bar and click on that icon my project wll be loaded on to the autocad.
    The problem is if i am closing autocad with project open then autocad is giving fatal error
    Is there any possible way to disable the functionality of close and Alt+F4 of autocad
    I am using visual basic 6.0 for my project
    6,452
    Default Re: Closing AutoCAD with project opens causes fatal error
    Check to make sure your project doesn't have any compile errors.
    LinkedIn
  1. 2012: Emptye error or warning when closing AutoCAD
    By info.48157 in forum AutoCAD General
    Last Post: 2014-03-12, 03:34 PM
  2. Project Associate Fatal Error
    By kdixon in forum AutoCAD General
    Last Post: 2009-03-23, 02:02 PM
  3. Error on closing Autocad
    By aquaman in forum VBA/COM Interop
    Last Post: 2009-01-29, 11:31 AM
  4. Project Navigator Problem...Fatal Error
    By kstrawn in forum ACA General
    Last Post: 2008-03-15, 05:41 PM
  5. Closing Autocad fatal error
    By jjacoby in forum AutoCAD General
    Last Post: 2005-06-11, 09:02 PM
