Just thought I'd share... these aren't 100% finished but you can always adjust them as required and most users will never notice what's missing. If you feel like reverse engineering them, these demonstrate how to do arrays of 0 and 1... They also should display correctly in plan and elevation (play with the level of detail in elevation)
Here's what's in the zip:
E-Control & E-Control-wall: which can handle any switch or dimmer configuration you want, either hosted or not.
E-Power-Duplex, E-Power-Duplex-Wall, E-Power-Multigang, E-Power-Multigang-Wall. The Duplex can be rotated, the Multigang has no major limits but doesn't rotate. Again, hosted and unhosted versions (which unfortunately have to be created separately because of limitations in the family editor).
Comments are most welcome.
