Thread: Converting a 3D line to a 2D ISO
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    Default Converting a 3D line to a 2D ISO
    Plain ACAD 2005 full.
    I have a pipe which has a difficult routing. I want to draw an ISO for this line.
    So i draw the 3D line of this pipe which i post here, with the current view as the view i want to use for my ISO.
    Now i want this converted to a 2D drawing.
    Is this possible, and can anyone help me with this?
    2004-12
    59
    Default Re: Converting a 3D line to a 2D ISO
    No problem
    Type the command UCS, then N for New, then V for view.
    You can then create a paper space layout using the current UCS
    Alternatively you can 'flatten' (make all Z values =0) using a suitable lisp routine.
    Alternatively you could leave the 3D object in the 2D drawing. (Not everything in a 2D needs to be 2D)
    Aled Taylor
    Design Engineer
    2006-01
    Belgium
    287
    I cannot correctly dimension ny ISO this way.
    That's not correct, i don't want to make all the Z values 0, i want to flatten my VIEW (or any view) make all Z=0 will only make the top view look correct.
    Same as first point
    All i need is a realy 2D drawing that looks like my 3D drawings current view.
    Tnx, johan
    2006-01
    Belgium
    287
    College here found it...
    Install DXB acad plotter
    Set the view you want
    make a plot (DXB extension)
    make a new drawing
    insert the dxb-file (dxbin)
    see result in attach
    http://usa.autodesk.com/adsk/servlet...linkID=2475323
    13,654
    Thumbs up Re: Converting a 3D line to a 2D ISO
    Quote Originally Posted by johan.degreef
    <SNIP>
    Hi
    Thanks for posting back a workable solution, I am sure others will benefit from such information in the future.
    Mike
  1. Converting 3D line drawings to 2D in plan view
    By Jayatissa in forum AutoCAD General
    Last Post: 2009-10-19, 11:57 AM
  2. Converting line segments into polyline
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2007-06-25, 01:56 PM
  3. Converting Arcs and Lines Into All Line Segments
    By CADdancer in forum AutoLISP
    Last Post: 2007-01-03, 02:26 AM
  4. Converting a firm from line drawings to BIM
    By brendan.bakey in forum CAD Management - General
    Last Post: 2006-07-17, 12:49 PM
  5. Converting Line Types
    By studio3p in forum Revit Architecture - General
    Last Post: 2004-01-29, 02:38 PM
