What's the difference between modelspace and paperspace?
Theres an ATP course on this I think.
Heres the link http://www.augi.com/education/archive.asp?page=293
Richard
Its ATP066 that you want.
In modelspace you draw things at their true size - a microchip or a housing estate or a spaceship.
In paperspace you also draw things at their true size but this literally represents your plot onto a piece of paper, 24" x 36" or 841mm x 1189mm, say.
Paperspace viewports are like holes cut in the paper and allow you to see modelspace objects and control the scale at which you see them.
HTH
To try to put it in a nut shell, the simplist way is to remember that paperspace is what you see printing out and model space is what you draw on or make a model on.
Hope this helps
You can also try the following linksOriginally Posted by hulin40
http://www.autocadcentral.com/Tutori...0/lesson10.htm
http://www.caddigest.com/subjects/Au...paperspace.htm
http://www.eng-tips.com/viewthread.c...=156379&page=1
Thanks!!!!!!!!!!!!!!!!!!
There is another essential diference that everyone over-looked..
In model-space area, an object with an lineweight, let`s say, 0.60 will always have a 0.60 lineweight, not depending of the zoomlevel... In paper-space, the objects lineweight is directly dependable of the zoom-level..
Jaffarhu:
I am not so clear
do you mean that after using the "zoom" command to change the viewport in the paper-space,the lineweight will not be the same as the previous?am i right?
what is ZoomLevel about ?Is it about zoom-realtime,zoom-window,zoom-previous?
Not necessarily. If using ctb files to create lineweight, the "zoomlevel" has no effect. Polylines with a defined width will plot thicker or thinner, depending on plot scale.Originally Posted by jaffarhu
So,the plot lineweight could only relate to the plot scale,as for the viewport in the paperspace is not necessary.but how to use ctb file to create lineweight?could explain plz?Originally Posted by scott.wilcox
