Results 1 to 7 of 7
Thread: CREATING TABLE FROM OBJECT DATA
    2005-05
    102
    Angry CREATING TABLE FROM OBJECT DATA
    I imported shape files, and the shape files have object data. Now, i would like to create a table format i can extract the object data information into a table.
    Can someone help me with that.
    thanks
    2001-12
    St. Louis
    5,347
    Question Re: CREATING TABLE FROM OBJECT DATA
    Quote Originally Posted by VBOYAJI
    thanks
    what program are you using, so the mod can figure out what forum this question would be best in?
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use BricsCAD, Revit, & Tririga, too)
    Technical Editor
    2005-05
    102
    Default Re: CREATING TABLE FROM OBJECT DATA
    I am using Autodesk Map 3D 2006.
    2005-01
    60
    One way would be to run a query of those objects and their object data to a report, import the report to excel, select the desired cell range copy and paste it back into a table.
    100 Club JeremiahM's Avatar
    Colorado Springs, CO
    186
    Use the "Convert Object Data to Database Links..." commnad in the Setup menu (or the Map>> Tools menu in the classic menus).
    Jeremiah
    Jeremiah McKnelly, GISP
    www.spatialbiz.com
    Weapons of choice: Map 3D, AUD, AIMS and SQL!
    2005-05
    102
    I have to create a target link, which i have no idead how to make one or even what it should look like.
    186
    Yeah, forgot that part, sorry. You need to attach the DB you want to put the data into. If you dont have one just create an Access DB and name it. Then you need to drag the .mdb file into the Project Workspace in Map and it will be attached. Then use the "Convert Object Data to Database Links..." tool.
    Jeremiah
    www.spatialbiz.com
  1. Getting object Data Table Name from Entity
    By sunsat05463998 in forum VBA/COM Interop
    Last Post: 2012-03-20, 10:04 AM
  2. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  3. Number of Records in Object Data table
    By raj_thapar2003 in forum VBA/COM Interop
    Last Post: 2006-07-31, 07:39 PM
  4. Object Table Data to Properties box
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-25, 11:49 AM
  5. Linking AutoCAD Object Data Table to Access table
    Last Post: 2006-05-02, 02:54 PM
