Thread: CUI file has become invalid. What is the next step?
    2006-02
    2
    Default CUI file has become invalid. What is the next step?
    I am using acad 2006 I assigned an icon to a command before dragging the command to the toolbar and it seemed to corrupt the cui file. When I try to open the CUI I get a message saying "the cui file you are attempting to open is invalid. Select a different cui file and try again." My toolbars are customized and I don’t want to start again. Any suggestions to correct this?
    CUI NOT WORKING!
    Thanks Ken
    13,654
    Default Re: CUI file has become invalid. What is the next step?
    Hi Ken
    Please note I have *moved* this thread from the CAD Mgmt. General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,654
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section...
    ID: TS1052254 - CUI file invalid
    Have a good one, Mike
    2000-01
    Seattle WA USA
    5,859
    Restore a backup. You do have a backup, don't you?
    Super Moderator rkmcswain's Avatar
    Earth
    9,673
    Agree with Robert.
    I learned early on to back up the CUI before attempting to modify it.
    Now if Autodesk could just integrate the backing up of the CUI before modifying the only copy. ...and maybe a CUIAUDIT command....
    R.K. McSwain | CAD Panacea |
  1. Invalid DBX file messages when opening a DWG file
    By Richard McDonald in forum AutoCAD General
    Last Post: 2014-02-17, 10:05 PM
  2. 2011: Invalid arx file
    By imacad in forum AutoCAD General
    Last Post: 2010-11-22, 06:31 PM
  3. invalid file handle
    By amindez9667 in forum Revit Architecture - General
    Last Post: 2010-11-22, 06:28 PM
  4. foo.ARX is an invalid file.
    By cesar.viudez in forum ARX
    Last Post: 2008-07-02, 02:19 PM
  5. invalid file ...
    By moshira_hassan in forum AutoCAD General
    Last Post: 2007-05-03, 07:06 AM
