Thread: Wall cleanup between walls in xref
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,724
    Question Wall cleanup between walls in xref
    Please see attached zip. x51311BF.dwg Is the host file, with xrefs attached. The walls will not cleanup properly with each other. Items checked:
    Cleanup group definition
    Cleanup Automatically
    elevation
    wall style
    Graphline position
    No wall merge conditions present
    The source file walls cleanup, yet when loaded as xref, walls appear to not cleanup.
    I noticed when playing with the display order of the walls in the source dwgs, by sending walls to the front/back of the draw order they would appear to cleanup. Even editing the xref in place in the host dwg & playing with the draw order, they seem to cleanup, yet when saving changes they are back to not cleaning up.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-09
    Madison, WI
    5,651
    Default Re: Wall cleanup between walls in xref
    ~student responds to master~
    Steve,
    I'm not sure what's wrong with them, but when I open your x51311bf file, I didn't have any red circles of death. When I went to a 3d view, I didn't see any lines out of plane. On a whim, you may want to copy and paste in to a clean template. That's worked for me before in that past when I can't figure what I did.
    Now, I did notice some red lines at your wall intersections that did seam a little odd. What I did find there is that if I turned off the "Stud Hatch" component the lines were gone. Now with regards to the "bump out parts" not cleaning up with the main wall, I tend to think the the problem (if that's the problem) is related to the graphline. It's turned on. So your drawing appears to not be cleaning up. I turn that off, and couldn't find anything wrong.
    Hope this helps.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2015-12
    4,724
    Thanks David! Sometimes the simplest solution gets overlooked. I tried copying/pasting into a new file & it worked. It doesn't answer the question of why, but it at least lets us move on. If I ever figure out what caused this, I'll post back in here. BTW, I never was getting a red circle of death, the shrinkwrap lines just weren't cleaning up.
  1. T cleanup with xref
    By Ed Jobe in forum ACA General
    Last Post: 2010-11-15, 03:38 PM
  2. 2008 aca xref element walls do not cleanup to construct
    By steve.yarnall in forum ACA General
    Last Post: 2010-04-16, 09:45 PM
  3. Interior wall cleanup with basic wall embedded in curtain wall
    By rdkuffel in forum Revit Architecture - General
    Last Post: 2008-01-10, 05:00 PM
  4. ADT 2006 - Wall Cleanup in Xref's
    By roberto.vasquez in forum ACA General
    Last Post: 2007-04-21, 07:03 PM
  5. Xref Wall Cleanup
    By BCrouse in forum ACA General
    Last Post: 2005-07-11, 08:02 PM
