Results 1 to 9 of 9
Thread: 3D Slice how make one side 2" larger without exploding
    2004-08
    137
    Question 3D Slice how make one side 2" larger without exploding
    I have a 3d square that needs to be made bigger. When I slice I didn't know how to make one side 2" larger without exploding. What can I do to make my 3d square, using slice, longer in Cad 2004 version
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: 3D Slice how make one side 2" larger without exploding
    You have to add a solid ( create or copy ) and then use union
    or extrude a face with command _solidedit
    You cut with slice
    : ) Happy Computing !
    kennet
    13,657
    Hi "sherflor" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    2004-12
    59
    Try 'Extude Faces', 'Offset Faces' or 'Move Faces'. At least one of them should work for you.
    Aled Taylor
    Design Engineer
    0,0,0 The Origin
    8,570
    It may be quicker to Scale the solid to larger than necessary then slice it.
    2002-05
    1,707
    Quote Originally Posted by jaberwok
    . . . hmmm, not if the solid has a complex shape
    kennet
    0,0,0 The Origin
    8,570
    Quote Originally Posted by kennet.sjoberg
    kennet
    True in general but, in this case, "I have a 3d square that needs to be made bigger".
    2002-05
    1,707
    Yes, but to "make one side 2" larger" ( OP:s ) must be easiest to use
    Command: _solidedit Face Extrude (select the edge) Remove (one unwanted face ) Enter 2" Enter Enter
    kennet
    2004-08
    137
    What works here is to use the separate command-Face-Move- this will actually extend the object too. Thanks for the good ideas. I now have more then one way of looking at this.
  1. 2013: LARGER THAN 12"
    By tcrawford1978 in forum Revit MEP - General
    Last Post: 2012-07-30, 07:26 PM
  2. show 4" or larger piping as a double line
    By davel.254027 in forum Revit MEP - General
    Last Post: 2011-09-09, 08:00 PM
  3. How can i make a larger rendered image?
    By markcrabbe01 in forum Revit Architecture - General
    Last Post: 2009-11-30, 05:26 AM
  4. 3d home worldrecord , front , side ,"jpg"
    By adil_shoukat in forum AutoCAD Gallery
    Last Post: 2008-02-14, 05:30 PM
