I suppose this is an XP question more than a CAD question, but it mostly affects my CAD work so...
Here's my situation: I do all my work on a laptop. I dock it in the morning, then take it home in the evening. I have syncronization software (that is almost working) so that I can make a specific directory on my laptop exactly match my main directory on the server (projects, AutoCAD support files, blocks, etc.). The entire server heirarchy is mapped to a single, persistent drive letter in XP Pro on my laptop.
What I'd like to do is have AutoCAD look to the server for everything when the server is present, and fall back to the local copy only when I'm not docked. (AutoCAD executables are installed locally, with a local license, fwiw). Is anyone aware of a way to ensure that type of switchover? Can it be done so that even files in the recently-opened menu get a soft path to "server if present; local if not"?
Why such machinations? Well, if I happen to be working at home, I'd rather not accidentally open and start working on a local file while at the office, then find out that someone else has worked on the network version at the same time. Or even just have a "mix" of files - I use mostly relative paths for xrefs, so it increases the chance of a WTF?!? moment when things plot screwy.
Also, I'm not to hot on using two different configuration files, as I have been known to move things around from time to time in the interface. If I fiddle with something in one configuration, I have to go fiddle with it in the other. Not very transparent. (And, lets be honest, sometimes I change things to get stuff to work just the way I like it, and then forget all the things I've changed to get there).
Anybody have a magic elixer that will give me a write-through style functionality?
Oh, almost forgot, I'm on 2006 but I am totally innocent of the workings of the "new" CUI, and I can't ((((()))))) my way out of a lisp routine.
