Results 1 to 6 of 6
Thread: Quick Leader Gap
    2003-11
    Ashland, Kentucky
    64
    Default Quick Leader Gap
    Is there a system variable or setting that controls the gap between the end of a leader line and the start of the MText?
    2004-08
    Iron Station, NC
    3,197
    Default Re: Quick Leader Gap
    it is setup under the dimension styles, it is on the tab that deals with text, it is
    "offset from dimension line"
    2003-11
    Ashland, Kentucky
    64
    That also controls the offset for the dimensions that are set to that style as well. So if I wanted the gap to be different between the leaders and the dims I would have to create style just for the leaders and set the offset distance there. Correct?
    2005-07
    2,356
    Smile Re: Quick Leader Gap
    Quote Originally Posted by jfields.61630
    Yes correct.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    or adjust each leader individually through the Properties dialog box
    2003-11
    Ashland, Kentucky
    64
    I appreciate all of the help. I was interviewing for a new position with a different company and was asked to take a CAD test. It mainly involved editing some text objects with leaders attached to them. The "design professional" was very particular about placement of the leader on the text--top of first line---bottom of last line. But when I placed new text using the quick leader it would put the text at quite a distance away from the leader. The drawing was protected so that I could not format any styles. It was a timed test so the extra time it took for me to go through the properties box made the test a bit harder than it should have. It was annoying me so I had to find the answer. Thanks again.
  1. Multileader vs quick leader with hatch
    By jpduhon in forum AutoCAD Annotation
    Last Post: 2008-03-01, 04:10 AM
  2. Quick Leader & mtext
    By jkramer in forum ACA General
    Last Post: 2007-01-11, 08:16 PM
  3. Replies: 5
    Last Post: 2006-10-11, 01:21 PM
  4. Quick Leader Settings
    By H.Hunter in forum AutoCAD Tips & Tricks
    Last Post: 2006-07-05, 01:59 PM
  5. Quick leader to a block
    By JOHN.73561 in forum AutoCAD Tips & Tricks
    Last Post: 2005-03-03, 09:39 PM
