Thread: Roof level and base offset wrong?
    100 Club mschroeder's Avatar
    2005-06
    Boston
    154
    Default Roof level and base offset wrong?
    I have a roof (created by footprint) hosted to a level with no offset. It should appear at that level, but it's not. Instead the roof object appears way off.
    Ideas?
    Attached is a screen capture with the properties.
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Roof level and base offset wrong?
    MSchroeder
    Try this
    Select your roof > Edit > Go To View > Choose Open View
    Select the System Family: Model Lines you drew for the footprint > go to their properties
    Have a look at the Constraints Parameter > Offset From Roof Base > set 0.0
    2005-06
    Boston
    154
    A non zero "Plate offset from base" parameter on a sketch segment was the culprit. Thanks Eddy.
    Michael
  1. 2015: Level head family that shows both Project Base and Survey Base
    By david_peterson in forum Revit Architecture - General
    Last Post: 2015-05-28, 04:11 AM
  2. 2013: How to get Base Level and Top Level of a selected column?
    By shogunnta423201 in forum Revit - API
    Last Post: 2013-11-14, 08:31 AM
  3. Pipe Filter by level offset - Reference Level Offset
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-04-02, 04:05 AM
  4. Roof & Ceiling Base Level Constraint vs. "Real" Framing
    By jeff.77718 in forum Revit Architecture - General
    Last Post: 2011-01-19, 12:55 AM
  5. Replies: 3
    Last Post: 2008-10-06, 10:24 PM
