Results 1 to 10 of 13
Thread: How do I minipulate Blocks on the tool Palette?
    2004-05
    Kearney, NE
    18
    Default How do I minipulate Blocks on the tool Palette?
    I have recently upgraded from "2000" to "2006" and I am learning to use the tool palates. I want to create a library that we can access from the tool palate to pull in our markers, blocks, etc. I copied Imperial to our server and directed all of our computer to access from that one enu file.
    I need to retrofit these existing blocks to our office standards and I am starting with the design tab. I found the drawing "Callouts (Imperial).dwg" that the tool palette is referencing. It has 23 different tags in this drawing. I have been able to update these tags to our standard sizes and fonts by doing an "edit block in-place" but how do I change the lines and layers associated with each tags block so that when I pull it off of the tool palette it shows up correctly in my drawing?
    2001-12
    St. Louis
    5,412
    Talking Re: How do I minipulate Blocks on the tool Palette?
    Quote Originally Posted by rodwhsa
    I'm going to move this from the CAD management forum, as I believe it will be better served here. Thanks.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,124
    Default Re: How do I minipulate Blocks on the tool Palette?
    The palettes link to a "master" drawing that contain all of the blocks. You wouldn't be able to link directly to a block that was just a drawing.
    Are you referring to the lines within the block definition? Those would be changed within the block itself like any other block.
    If you are referring to the layer, color, linetype, etc., you can right-click on the tool within the palette to pull up the properties. Within the tool property dialog box, you will be able to set those values to your chosen values.
    2004-05
    Kearney, NE
    18
    So can I go find this "Master" and change the block there to fit our standards, or can I take our standard blocks and place them in this master file, so I can access them from the tool palate?
    Currently my office has a sheet that we open and copy/clip our standard tags, markers, etc. from. I know this sounds ridiculous but we do not have any CAD management, and this was set up years ago and know one has ever advanced the system. I want to make the current blocks on the ACAD tool palette look similar to our office standard blocks, so I can use my tool palette instead. Obviously I have limited knowledge on how to do this.
    2002-01
    jUSt Here (a lot)
    9,124
    You can use the Design Center to create a new palette based on blocks from an existing drawing. You will need to set each tool's properties. You can then click customize on the tool palette to export that palette. This would allow you to import it to other machines.
    Active Member Jordan Truesdell's Avatar
    2016-01
    Virginia, USA
    91
    Opie,
    Your suggestion is to create a new pallete. Is that because you _can't_ modify the tools in the default pallete, or because it is poor management practice to modify the tools in the default pallete?
    2002-01
    jUSt Here (a lot)
    9,124
    Quote Originally Posted by Jordan Truesdell
    Opie,
    It seemed that rodwhsa was attempting to modify the blocks from the provided OOTB palette. If he already had a drawing that contained all of the blocks he needed, it may be quicker to create a new palette from the company's master block drawing.
    You can modify the OOTB palettes as much as you want. I was only suggesting the new palette route due to speed of having to change the OOTB palettes.
    2004-07
    Detroit Michigan
    2,508
    How would you go about creating a tool pallete from a drawing that contains X number of blocks? All of my blocks would be in 1 file?
    I
    2002-01
    jUSt Here (a lot)
    9,124
    Quote Originally Posted by Robert.Hall
    I
    These are the steps I would take to accomplish this.
    1. Open the Design Center.
    2. Navigate to the folder that contains the drawing that contains the desired blocks.
    3. Right-click on the said drawing.
    4. On the pop-up menu, select "Create Tool Palette"
    This should create your tool palette for you with the default settings. You will then need to modify each tool with the desired layer, color, linetype settings or any other settings that you desire.
    BTW: I also found out that the Design Center will create a tool palette of a complete folder, therefore the blocks do not need to be within a master drawing.
    2001-12
    St. Louis
    5,412
    Quote Originally Posted by Opie
    jackpot... ... i'll have to toy with this (i'll admit, I haven't used tool palettes much... ~stands up~ my name is melanie... and I'm a command line junkie ~sobs~ )
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Tool palette blocks to use UNC path to locate blocks
    Last Post: 2012-07-16, 12:03 PM
  2. Replies: 0
    Last Post: 2011-10-11, 10:00 AM
  3. Tool Palette Blocks
    By randyspear in forum AutoCAD Customization
    Last Post: 2009-11-10, 12:22 AM
  4. Alphabetize the blocks in my Tool Palette?
    By bmonk in forum AutoCAD Customization
    Last Post: 2007-05-10, 06:28 PM
  5. Creating Tool Palette from Blocks
    By mgagnon in forum ACA General
    Last Post: 2005-04-06, 09:00 PM
