Results 1 to 7 of 7
Thread: Unable to detach a Xref
    2004-08
    137
    Question Unable to detach a Xref
    I have two paperspace layouts. Each has a border. I wanted to detach the border and attach a new border to the layouts. However, I get a message ,"unable to detach. Multiple refer. detected". So this means I cant detach the old border and attach the new border?
    2001-12
    St. Louis
    5,372
    Question Re: Unable to detach a Xref
    Quote Originally Posted by sherflor
    I'm not sure what you mean by border? do you mean a titleblock? something that is x-refed in, though, right?
    can you just delete it? maybe a screenshot would help me to understand, I'm a little slow and pictures can help.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use BricsCAD, Revit, & Tririga, too)
    Technical Editor
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Unable to detach a Xref
    Let say that you have 2 xrefs attached to your MyDrawing, Xref1 and Xref2
    if Xref2 has Xref1 attached and you try to detach Xref1 you got that message.
    MyDrawing
    |____Xref1
    |____Xref2---Xref1
    you have to detach Xref 1 from Xref2 first
    and then detach Xref1 from MyDrawing.
    : ) Happy Computing !
    kennet
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,681
    Do both layouts contain the same xref? If so, you will need to delete one of them before you will be able to detach.
    HTH
    13,656
    Hi "sherflor" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Have a browse of the following thread...
    Detaching xrefs - "Unable to detach. Multiple references detected"
    Have a good one, Mike
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    You have 2 options. One erase one of the xrefs and then detach the other. Or, you can repath the xref and both xrefs will be updated.
  1. Multiple Drawing Xref Detach
    By martyk in forum AutoLISP
    Last Post: 2012-08-05, 07:32 AM
  2. Xref overlay without detach
    By cadprog in forum Dot Net API
    Last Post: 2008-11-04, 08:46 AM
  3. Unable to detach xref
    By michael.12445 in forum AutoCAD General
    Last Post: 2008-02-28, 01:19 PM
  4. Detach Xref by Selecting
    By wommack in forum AutoLISP
    Last Post: 2006-05-17, 10:55 PM
  5. Cannot detach a xref
    By kleenhippie in forum AutoCAD General
    Last Post: 2005-08-24, 04:03 PM
