Results 1 to 7 of 7
Thread: Re-register AutoCAD 2006 after reinstall
    2006-01
    Unhappy Re-register AutoCAD 2006 after reinstall
    My system crashed and I can not re-register Autocad 2006 after a reinstallation. The message indicates I have used my registration already and to contact Autodesk. This was two weeks ago and I have not received any response. Has anybody else had a similar problem? Do you have a work around? I'm tired of getting the pop up telling me I have this many days left to register or I can't use Autocad.
    2001-12
    St. Louis
    5,342
    Cool Re: Re-register AutoCAD 2006 after reinstall
    Quote Originally Posted by newberry
    It is my understanding that you have to call up autodesk and reregister that way, your reseller might be able to walk you through that?
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Re-register AutoCAD 2006 after reinstall
    If you had either written down, printed out, or copied the file that had the registration key in it, you shouldn't have to reregister after a reinstall.
    Just make sure the key file is in the right place.
    This may not do you any good at this point, if you blasted it away when you did your reinstall, but it's something to keep in mind for next time...
    2001-12
    St. Louis
    5,342
    I believe that with the newer versions (05 and 06) you can no longer retype the same registration approval number (or whatever they call them). a new number is required with each authorization of the single product.
    Quote Originally Posted by richards.64879
    Melanie Stone
    @MistresDorkness
    Technical Editor
    BIM/VDC Management Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,819
    As mentioned above, you'll need to contact your reseller and they'll be able to help you out.
    Brian Myers
    VDC Design Office Lead | Digital Delivery Lead | BIM Management
    Visit my LinkedIn Profile for more information.
    2004-02
    Colorado
    1,986
    Quote Originally Posted by Wanderer
    Strange. I just did a reinstall of 2006. (I upgraded a 2004 installation, and Autodesk says "you MUST uninstall the old version within 60 days", but then when I uninstalled 2004, it broke 2006! A repair on 2006 didn't work, so I had to uninstall and reinstall. Thanks, Autodesk. )
    I did not reacitvate. It all works.
    AFAIK, the code you get is keyed to certain hardware components on your machine. So, if you change certain hardware components (i.e., upgrade the CPU), you'll probably have to reactivate. If you get a new computer you have to reactivate. If you reinstall without changing hardware, the old key should work. At least, that was my understanding, and it seemed to be confirmed by my one reinstallation....
    2003-02
    St Louis, Missouri
    1,819
    That is true, the old Key should work assuming that you printed it out or have the file backed up. In theory as long as the key still resides on your system you should be able to reinstall AutoCAD as many times as you need as long as your hardware has not changed. But, if your "key information" is not available you'll officially need to contact either Autodesk or your reseller if you don't wish to use one of your installations or if you can't install it any more times.
    Brian Myers
  1. Replies: 6
    Last Post: 2013-06-28, 06:18 PM
  2. EXCEL Drawing register using Autocad Title Block Attributes
    By simon_coupland in forum AutoCAD Customization
    Last Post: 2010-05-24, 10:13 AM
  3. Error 1309 on AutoCAD 2007 reinstall
    By tyrosch in forum AutoCAD General
    Last Post: 2006-10-18, 03:09 PM
  4. Reinstall Express Tools in AutoCAD 2005
    By pmartinez in forum AutoCAD General
    Last Post: 2004-11-01, 09:11 PM
