Thread: multi select dialog box
    2004-12
    42
    Default multi select dialog box
    I would like to be able to multiselct in a dialog box
    not sure of the setting for this
    ' setup info for browse button
    Sub getdefaultfile()
        CommonDialog1.Filter = "all files (*.dwg) |*.dwg|"
        '    & "Pdf FIles (*.pdf) |*.pdf|"
        '    & "Pdf FIles (*.dwg) |*.dwg|"
        CommonDialog1.FilterIndex = 2
        CommonDialog1.DialogTitle = "Select File"
        CommonDialog1.InitDir = mssearchpath
        CommonDialog1.ShowOpen
        newfilename = CommonDialog1.FileTitle
        lsttomove.AddItem CommonDialog1.FileTitle
    End Sub
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Turlock, CA
    6,420
    Default Re: multi select dialog box
    I would abandon the CommonDialog control, especially if you're using vba, since the vb license doesn't allow for use in vba. Instead, use the windows api. Here is a class that wraps some file api's. I got ifrom Randall Rath, but I added the functionality for multiselect options.
    C:> ED WORKING....
    LinkedIn
    2004-12
    42
    Thank you for the info works great
    But I do have another question
    When I was using the common dialog control I would use
    with newfilename being what was selected
    guess i am not sure what to use to get what i have selected in the dialog box
    thanks again
    Turlock, CA
    6,420
    Here's a sample of how you might use the class.
    Public Sub OpenFile()
        'sample to show how to use FileDialogs
        Dim objFile As FileDialogs
        Dim strFilter As String
        Dim strFileName As String
        Set objFile = New FileDialogs
        'desc,filter combinations must all be separated with pipe char "|"
        strFilter = "All Files (*.*)|*.*|Drawings (*.dwg)|*.dwg"
        objFile.OwnerHwnd = ThisDrawing.hWnd    'bind the dialog to the window
        objFile.Title = "Open a drawing"
        'default dir is CurDir
        objFile.StartInDir = "c:\"
        objFile.Filter = strFilter
        'return a valid filename
        strFileName = objFile.ShowOpen
        If Not strFileName = vbNullString Then
            'use this space to perform operation
            MsgBox strFileName
        End If
        Set objFile = Nothing
    End Sub
    C:> ED WORKING....
    LinkedIn
  1. Replies: 6
    Last Post: 2015-11-09, 06:38 PM
  2. File Multi Selection Dialog (and Folder Select)
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-02-18, 04:46 PM
  3. Multi select Bolted Connection
    Last Post: 2013-09-27, 06:52 AM
  4. Multi Select Tab
    By awarren in forum AutoCAD General
    Last Post: 2009-08-28, 01:49 PM
  5. Select File dialog box default
    By gabem in forum AutoCAD General
    Last Post: 2005-04-29, 05:04 PM
