Thread: Block Definition
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Block Definition
    I have a Block of a Stair tower in my plan that I have copied 8 times
    One of the Stair Blocks I would like to show as a Different color, but still
    have it part of the original. I can explode it, but is there a way to keep the
    block and have it show in mutable colors.??? Not just the layer color.???
    2002-09
    Madison, WI
    5,682
    Default Re: Block Definition
    Is this a plain Acad block or an ADT object? Was it created as an element? What layer did you create it on. Blocks created on layer 0 will take on the color of the layer they are inserted on. As far as I know you can't. If all 8 blocks are in the same drawing the answer is no. You can't display the same block 2 different ways in the same drawing. Update one, they all update. If it's and ADT based object and it contains a style, you can do a copy/assign new style and create a different block.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2021 w/ BIM 360 - Navisworks - Ensacpe - Lumion - Windows 10 OS - i7-10850H 2.7GHz 64GB Ram - Nvidia Quadro RTX 3000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. Block definition variable
    By bjrochford958510 in forum AutoCAD General
    Last Post: 2012-10-02, 02:38 PM
  2. un-erase a block definition
    By matthew.wiseman in forum Dot Net API
    Last Post: 2010-01-26, 03:24 PM
  3. Renaming block definition
    By jbeaman in forum Dynamic Blocks - Technical
    Last Post: 2007-08-09, 01:09 PM
  4. How to update block definition
    By dhendrickson in forum AutoCAD General
    Last Post: 2007-06-07, 12:19 PM
  5. Replies: 0
    Last Post: 2006-10-11, 09:10 PM
