Thread: Column cut pattern override weirdness
    100 Club Jos Arpink's Avatar
    2001-12
    Vancouver BC Canada
    129
    Default Column cut pattern override weirdness
    Ran across this one today in Revit Structure 2008
    In Visibility/Graphics overrides, I was trying to override the column cut pattern color but nothing happened. Just for fun, and only after an appropriate amount of hair-pulling, I tried the Projection/Surface pattern override and, voila!, it stuck. A bug perhaps?
    Jos Arpink
    Revit Moderator
    2004-07
    Milwaukee, Wisconsin
    530
    Default Re: Column cut pattern override weirdness
    Same thing here Jos . . . Thanks for the heads up.
  1. 2015: cut pattern override view template
    By jledgewood in forum Revit Architecture - General
    Last Post: 2015-03-31, 02:33 PM
  2. Replies: 1
    Last Post: 2013-01-28, 12:52 PM
  3. Can't override surface pattern with a model pattern?
    Last Post: 2010-06-22, 07:45 PM
  4. no pattern = no override
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-06-16, 04:29 AM
  5. Override detail Component Pattern
    By sfaust in forum Revit Architecture - General
    Last Post: 2007-04-27, 07:03 PM
