Results 1 to 9 of 9
Thread: Convert DWG to PCX
    2005-12
    7
    Question Convert DWG to PCX
    a client needs one of our drawings converted to a PCX file. I have no idea how to do that.
    Any help ut there?
    Thanks
    Mike
    13,653
    Default Re: Convert DWG to PCX
    Hi Mike
    Please note I have *moved* this thread from the CAD Mgmt. General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,653
    Hi
    PCX is a valid file type, when outputting to a file via the _.Render command.
    PCX can also be outputted via the _.Plot command when a Raster File Format output devices has been set-up via "Add-A-Plotter Wizard" using the Raster Heidi Driver and selecting "ZSoft PC Paintbrush PCX (ZSOFT PACKBITS Compression)" as Model type.
    Have a good one, Mike
    2005-12
    7
    Mike, thanks for quick reply but you lost me in several areas. Must be the Monday Morning Syndrome... I cant seem to find the Raster Heidi Driver on this system here at work. Is it part of the regular Acad plot styles?
    Also, what is Zsoft PCX?? Will that be a selection window when I set up the Heidi Driver
    plot style?
    Thanks again for your help.
    Mike
    13,653
    Quote Originally Posted by mreynolds9
    <SNIP> I cant seem to find the Raster Heidi Driver on this system here at work. Is it part of the regular Acad plot styles?
    plot style?
    Hi
    Double click on "Add-A-Plotter Wizard" ( shortcut ) or go directly to "addplwiz.exe".
    Add Plotter wizard opens.
    Add Plotter - Introduction Page -> Click "Next" button.
    Add Plotter - Begin -> Select radio button "My Computer" -> Click "Next" button.
    Add Plotter - Plotter Model -> From "Manufactures" window select "Raster File Formats" -> From "Models" window select "ZSoft PC Paintbrush PCX (ZSOFT PACKBITS Compression)" -> Click "Next" button.
    2005-12
    7
    Smile Re: Convert DWG to PCX
    BINGO !!! great .. I owe ya one Mike..
    Thanks very much.
    Mike---in Wisconsin
    One simple process I use to create a JPG file (similar to PCX, I believe) is to do the following:
    1. In the AutoCAD file, zoom in as close as possible to what I want in the JPG file.
    2. Hit the Print Screen button on the keyboard.
    3. Open up Microsoft Photo Editor.
    4. Under the Edit Menu, select "Paste as New Image." The AutoCAD screen appears in the new JPG file just created.
    5. Crop out the unwanted stuff.
    6. Save to PCX format if necessary.
    Good luck,
    Woody
    2005-12
    7
    Woody, great tip !! I forgot all about that PRINT SCREEN capability.
    We're doing some neat stuff here now---thanks to you.
    Client still wants PCX files (and we are viewing them with Corel Draw) but the jpg's look great.
    Thanks
    Mike
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Instead of using the JPG file format, you better use the PNG file format, it’s a lot smaller and the quality is the same. Also you can open this file with almost every program.
    Check page 10 in this AU course handout.
    http://www.augi.com/education/auhand...004/ED24-1.pdf
    Otherwise, here you find other great converting tools.
    http://www.freedownloadscenter.com/B...-pcx-free.html
  1. 2010: convert dgn to dwg
    By mkr_trash in forum AutoCAD General
    Last Post: 2012-10-08, 12:24 PM
  2. Convert SDF to SHP
    By dkitoko in forum AutoCAD Map 3D - General
    Last Post: 2008-11-20, 03:42 AM
  3. Convert a PDF into a DWG
    By IanR in forum AutoCAD LT - General
    Last Post: 2006-08-18, 01:02 AM
  4. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
