Thread: Pipe Invert Updates
    2006-03
    Twin Cities, MN
    Default Pipe Invert Updates
    While using Pipeworks my inverts will not update and I am not able to change them. Pipe calcs are downstream to upstream and I can not update inverts (only the first one in the run) ... is there a setting that is on or off ... thanks
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Default Re: Pipe Invert Updates
    Quote Originally Posted by rebekah_clark.109001
    You can only edit the first beginning invert and the ending inverts. The beginning inverts are determined by the "node drop" entry. You should be able to edit the slope and ending inverts of each pipe, using the "edit data" option under conceptual plan or conceptual profile in the pipes menu.
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,431
    You can edit the slope between the 'Nodes' to get the invert you want as well as editing the node drop as Ammon suggested. If all of your nodes have the same drop, you can set that in the Structure editor so you won't have to edit each one. You can also associate incoming pipe runs with your main run by typing the exact 'Name' that you gave each run into the Lateral columns at the stations where they intersect with your main run and the editor will pick up the invert for you to make it easier to check for busts and it even draws your pipe ellipse in the profile for you.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. pipe invert labeling
    Last Post: 2014-10-27, 02:23 PM
  2. Pipe Depth to Invert values
    Last Post: 2013-12-01, 10:50 PM
  3. 2011: Edit Pipe invert in Pipe vista results in instant crash
    By nelson in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-02-23, 04:29 PM
  4. Pipe Invert?
    By kane333 in forum AutoCAD General
    Last Post: 2009-02-02, 03:50 PM
  5. Pipe Invert Editor
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-05-01, 08:42 PM
