In the drawing attached you see an example that is possible with the command I mean.
If you can make this with the Grid & Snap, just write it down and post it. plz
HiOriginally Posted by Olaf.Banckaert
As far as I know ( which means nothing ), there is no Standard AutoCAD command that automatically draws a Building Grid ( as per your above example ).
I believe ADT & Revit have such functionality.
There are routines ( LISP / VBA ) available for AutoCAD that will automatically draw a Building Grid ( Search here on AUGI or the web ).
Have a good one, Mike
Damn, damn, damn, it was so easy I lOOked over it.
Command: Columngrid
You can also use the toolpalet ‘Design’ and select here ‘Structural Column Grid’
This only works in ADT (sorry mike, forgot to mention it at the beginning of this thread).
See example attached, every thing you see is done with the command.
Please note I have *moved* this thread from the AutoCAD 2006 General forum to this one...
Thanks, Mike
Forum Moderator
